Latest: DanDan17
Overall: 17128
Online Now [115]:
Visitors: 114
Today: 35918
Total: 100636305
Forums › The Car › 206 Problems › Passender footwell leak
daninmanchester
PostPosted: Sat Aug 02, 2014 6:50 pm Up
After a down pour today I noticed the passenger footwell was very wet on the drivers side. Any suggestion as to where the best place to start looking is?
Are there any common points/likely sources?
copey
PostPosted: Sun Aug 03, 2014 2:17 am Up
check the seals around the doors, or sunroof if you have one
02 2.0 hdi d turbo
PostPosted: Sun Aug 03, 2014 3:42 am Up
Make sure the drain holes at the bottom of the door are clear of crap.
Have you ever had the door cards off? Did you reseal the membrane properly?
And yep that was definitely a heavy downpour, the thunder seemed to runble on for hours.
daninmanchester
PostPosted: Sun Aug 03, 2014 8:18 am Up
No sunroof and no, I've not done any maintenance on the doors. Just a standard service so doubt they would have?
No thunder here Sad but lots of standing water on the road.
I'll check the seals and drains.
They seems okay a few weeks ago when I gave it a clean, but it does accumulate leaves and seeds where it is parked.
