Online Now [408]:
Visitors: 407
Today: 131734
Total: 154820094
Forums › The Car › 206 Problems › rough idle and nearly cuts oot
chefboy1985
PostPosted: Mon Aug 11, 2014 9:08 am Up
All yesterday car was fine until I was driving back hme and pulled up to a roundabout and the car was nearly stalling,thot was a one off as when I got up to motorway speed again it ran fine.stop outside my house and let it idle it was running rough as hell!!!anyone had the same problem?it's a 2005 206 gti,it's was also really heavy rain last night so not sure if that could have anything to do with it?
I am cleaning the throttle body and sensors to c if that will help.
206Info_SW_Scots
PostPosted: Mon Aug 11, 2014 9:14 am Up
Maybe empty out any water in the air filter housing. Not sure where it is on yours but my 206 1.4 it's way down under the Front bumper so any puddles etc could splash in there.
206 SW 55 Plate - Happy Owner
chefboy1985
PostPosted: Mon Aug 11, 2014 9:32 am Up
don't that mate,I have an induction kit.I was thinkin the same so check fitter it's a wee bit wet so ran the car with it off just there and still the same.only thing I have dne different was put momentum99???
206Info_SW_Scots
PostPosted: Mon Aug 11, 2014 9:40 am Up
Momnetum99 is an additive I presume. Maybe it's clogged up some sensor. Can't help mate.
VorTechS
PostPosted: Mon Aug 11, 2014 9:48 am Up
Staff - Vortechs
Try cleaning the idle control valve/stepper motor and throttle housing, there's a 'HowTo' lurking here
** Just realised it's 2005 and I know nothing about GTi engine's - but think the later ones aren't cable operated?
But I'm presuming it still has a stepper motor and air bypass in a similar manner....?
chefboy1985
PostPosted: Mon Aug 11, 2014 11:10 am Up
I have cleaned all that out but still the same am stumped!!the car is also decated but was running fine and when I tried to c if there was any faults cumin up using my torque app apart from the usual one because there is no cat.goin to use the fuel that in it then put vpower back in,as I says before it's the only thing I have dne different.
wolfbane468
PostPosted: Mon Aug 11, 2014 4:40 pm Up
I had this issue cleaned ICV and replaced my engine earth seems to have sorted for now
josh206xsi
PostPosted: Tue Aug 12, 2014 4:57 am Up
I had a very similar problem when I first had my XSi, turned out the spark plugs just needed changing, its worth taking them out and checking they look ok, as it wouldn't cost anything just for a look.
Obsidien black Xsi
chefboy1985
PostPosted: Tue Aug 12, 2014 11:12 pm Up
Wel to my amazement on the way hme from nightshift, I stopped at a junction and it was idling perfect!!!!!stop ootside my house and let it run to c if it started to play up but nothing happened, no dout it Wil reappear again but for now it seems to be fixed.thanks for all the input Ladz.
Danw_VVT
PostPosted: Wed Aug 13, 2014 2:08 am Up
Bit late but it had the same issues with my 206 1.4 sport
Turned out mine was because I had a decat system and the post cat lambda was sending signals say the car was running to rich so obviously reducing the amount of fuel the car ran.
Unfortunately mine was all the time and even using the resistor trick didn't work also tried a sports car system and nothing cured it
