Latest: TigerHunters
Overall: 17144
Online Now [61]:
Visitors: 60
Today: 3772
Total: 115877221
Forums › The Car › 206 Problems › 206 pedal shake!
206 pedal shake!
DjSerious
PostPosted: Sat Aug 16, 2014 1:04 pm Up
Why does my pedals shake on acceleration up to about 40mph?? Had new coilovers 50mm drop all around, then on the front new wishbones, new anti roll bars, new brakes (discs & pads), new wheel bearings, new engine mounts, new gearbox mount, 2 new tyres, tracking and balanced and still it shakes!!!
Could it be top mounts, arms or maybe clutch??
my1st206
PostPosted: Sat Aug 16, 2014 3:49 pm Up
Buckled alloy ? Have you tried two diff wheels on front?
2003 1.1 Look
DjSerious
PostPosted: Sun Aug 17, 2014 6:32 am Up
Please can someone help!!
Could it be top mounts, or maybe clutch??
Vexs
PostPosted: Sun Aug 17, 2014 6:35 am Up
No need to ask the same question twice within a short period. Someone replied to your previous post, have you even seen it?
My GTI 180
My Old 1.4 8v
PostPosted: Sun Aug 17, 2014 7:11 am Up
What He Said
Topics merged. This is the 3rd time you've asked the same question. Next one will just get deleted.
DjSerious
PostPosted: Sun Aug 17, 2014 7:20 am Up
New to this sorry
PostPosted: Mon Aug 18, 2014 6:17 am Up
get it test driven by a knowledgeable mechanic. Someone with sensitive hands and a**e can usually tell by the feel of the vibration.
southwestchap
PostPosted: Wed Aug 20, 2014 9:22 am Up
driveshaft/cv joint issue possibly.
Project2062014
PostPosted: Fri Aug 22, 2014 6:16 am Up
New clutch & cv probably wont do anything ! I Said new clutch & cv joints probably wont do a thing ! The only way movement would be affecting accelerator pedal would be as something is lose or leaning and in-contact with the pedal or cable . If cable i would think the revs would be affected .if not
fixing bolts nuts that hold the pedal in place . Check cable not been caught in drop ! Could be a bodge fix on it ? Kinda of a weird issue to read about and sort without a look ! Fine vibration or heavy ? Change vibration with more revs ? Is there a point in that the pedal is press to 50% down and it stops ? When does this vibration stop affecting the pedal ? If its cable that it . I said if its cable that is .
