Latest: sparrowdclxvi
Overall: 17139
Online Now [456]:
Visitors: 455
Today: 61084
Total: 112745036
Forums › The Car › Solved 206 Problems › Right indicator has started repeating very fast ?
206Info_SW_Scots
PostPosted: Sun Aug 31, 2014 11:49 am Up
Before I start checking solenoid etc, anyone had this ?
206 1.4 SW 2005. 113,000 miles.
206 SW 55 Plate - Happy Owner
206Info_SW_Scots
PostPosted: Sun Aug 31, 2014 12:36 pm Up
Fixed !
Went out to car. Left side fine. Both stalks fine. Hazard warning worked both sides fine. Took left front bulb - the one in the headlight cluster - out as the right hand one was off when I turn on the right hand indicator stalk. The right hand side now worked perfect. So the cluster orange bulb is dud. So the fast repeating must be a warning the bulb is out.
Cheers anyway.
206Info_SW_Scots
PostPosted: Sun Aug 31, 2014 12:39 pm Up
Plz move to solved section.
PostPosted: Sun Aug 31, 2014 1:05 pm Up
Pretty normal on most cars for the indicator to flash faster on the side where a bulb is out.
