Online Now [1076]:
Visitors: 1075
Today: 174921
Total: 155265303
Forums › The Car › 206 Talk › 206 1.4 HDi SW
206 1.4 HDi SW
Forum Index › 206 Talk
Vexs
PostPosted: Sat Aug 30, 2014 4:34 pm Up
Rear axle is the main one as James stated.
Faulty comms2000 unit is a common problem too (stalk controls). Loose stalks, indicaters not sticking when signalling, High beam being intermittent. Not a huge problem £150 for a new unit, fit yourself if you fancy it, pretty straight forward.
My GTI 180
My Old 1.4 8v
James3107
PostPosted: Sun Aug 31, 2014 6:11 am Up
I haven't calculated a true mpg, but I get about 85-90 miles to £10 of diesel. And that's all town stop start driving motorway will be more. I guess 60mpg ish. I drive very economical though.
1.4 HDi Indigo Blue
James3107
PostPosted: Sun Aug 31, 2014 6:13 am Up
Isn't there a guy on eBay that fixes your unit for £20? My indicator goes straight from indicating right to left on a sharp corner but it's never bothered me enough to get it fixed.
1.4 HDi Indigo Blue
Orta
PostPosted: Mon Sep 01, 2014 5:37 am Up
Cheers for the input guys! I know it'll be slow the mrs used to have the 1.4 tdci fiesta, which I believe is the same engine? But for commuting and day to day duties the prospect of 60mpg vs the 40mpg I'm getting from my Toyota auris at the minute is proving irresistible.
Any other bugs, electrics etc. to look out for when viewing? As I'm calling someone about 1 this evening...
2006 206 1.4 HDi SW Verve
Orta
PostPosted: Mon Sep 01, 2014 5:38 am Up
Ps... Gonna try a 2.0 as well Wink
James3107
PostPosted: Mon Sep 01, 2014 8:56 am Up
Check the indicator stalk doesn't feel too loose as that could be a new comm unit. Which is £150 if it bothers you. Although they can be repaired guy on ebY charges £20
Test drive it for the rear axle which is a very common fault.
Also if you can try park it uphill and start it. These have crap fuel lines under the airbox and are prone to getting small air holes in them. Squeeze the priming bulb and see if it feels loose or if air is in it.
Peugeot charge £120 for the privelege of new lines. Although like split and I just rerouted a universal 5mm fuel pipe. Which is thick rubber and haven't had a problem since.
Yes it's same engine as fiesta 1.4tdci.
1.4 HDi Indigo Blue
DREWDEN
PostPosted: Mon Sep 01, 2014 1:08 pm Up
If its got air con make sure the slow and high speed fan is working, high speed fan should come on at roughly 85 degrees.
Loads of threads with this problem.
Resistor and relays corroding.
206 2ltr Hdi glx 53 plate
pro_steve
PostPosted: Tue Sep 02, 2014 3:10 am Up
The 1.4 and 1.6 are ridiculously good on fuel. Maybe a bit less reliable than the 2.0 but not if you remove the Dpf from the 1.6. All respond well to remaps, but the 1.4 will always be slow no matter how much you spend on it, but its not going to use much fuel and road tax is really cheap.
The 2.0 can be picked up cheaply and is indestructible so you may actually save money in the long run even though it will use a bit more diesel. The 2.0 you'll usually stay above 50 mpg average, the 1.6 more like 60mpg, the 1.4 is better still if you can drive it slowly, however I found I had to thrash it to get anything out of it so tends to use more with my style of driving.
I've had all three in 206s and various other cars, you can't beat the 1.6 110 in my opinion. Don't know why people give them such bad press to be honest. Look after the car and it will look after you.
www.hdi-tuning.co.uk
southwestchap
PostPosted: Tue Sep 02, 2014 5:10 am Up
I drove a 1.4 HDi daily for three years, racked up 70k miles and never really had an issue. Yes they are a little sluggish but apart from wear n' tear parts the thing has been absolutely brilliant. 176,000 miles now and just about to get intercooled and a new style turbo (and thats not because the old one is knackard)
I also have the 2.0HDi SW and that pretty good, running a stage 1 and drives well. Rear wiper and demister doesn't work (standard for a SW) but its quite nice to cruise along in.
Shadowstalke
PostPosted: Tue Sep 02, 2014 8:26 am Up
What He Said
My 1.6HDi is well looked after, and it looks after me (cruising past BMW's and Audi's up hills is just so satisfying).
A DPF-delete and Remap makes a 1.6 110 into a pretty serious machine...
1.6HDi. Pull like a train. Smokes like one too!
No Smoke, No Poke!
Orta
PostPosted: Tue Sep 02, 2014 10:58 am Up
Thanks! Had many 306s so know the pain of having no a/c!
Orta
PostPosted: Tue Sep 02, 2014 10:59 am Up
What's the fix for the rear wiper and demister? The latter is essential in my book as it's going to carry a dog who likes to breath heavily onto the boot glass.
southwestchap
PostPosted: Tue Sep 02, 2014 11:09 am Up
there's is a few threads kicking around the internet about fixes for it. Effectively the screen has 'electrical tracks' which break/peel off.
What I've seen done is actually use wire and stick it to the glass. Bit of a bodge but a new glass from peugeot would be bend over prices for sure.
Haven't fixed mine yet as I'm using the car daily, using rain-x for the moment haha. When the 1.4 is back on the road I'll look into it. You maybe lucky and get one that already works.
Orta
PostPosted: Mon Jan 05, 2015 2:34 pm Up
What is actually the difference between trims? I'm looking at a verve and and an s model and it seems the only difference is alloys and fully colour coded. Otherwise they're all the same... Every trim seems to be. Am I missing something subtle?
PostPosted: Mon Jan 05, 2015 2:55 pm Up
206 trims are a minefield as there has been so many different badges stuck on from the factory over the years.
How old is the S spec 206 as even that had trim upgrades on the later versions, one example:
Early S spec had non sport front bumper without front fogs.
Later S spec had sports front bumper including front fogs.
Page 2 of 3
