Online Now [1034]:
Visitors: 1033
Today: 312736
Total: 146443978
Forums › Welcome › 206info forum FAQ's › 206 lx 1.1 electrical problems
Forum Index › 206info forum FAQ's
peeky72
PostPosted: Wed Sep 03, 2014 1:32 pm Up
Sad hi i have a 206lx 1.1 2000 and my horn stopped working a few days ago and now my electric windows and sunroof have stopped working i have checked fuses and earth wire can anyone help me please thanks.
PostPosted: Fri Sep 05, 2014 2:10 am Up
Well since you have a sunroof,make sure that there is no water going down the BSI unit down,as that will cause u problems,about the horn,it need a new one,or you can check it's plug if you get 12V when trying to use the horn,if there is a 12V,then a new horn needed,if not,then there is a problem in wiring,same apply for the sunroof.
peeky72
PostPosted: Fri Sep 05, 2014 7:52 am Up
i have put a polythene sheet over the whole car so it does'not get wet and tried a electrical tester on the horn but no power going to it think i'll have to take it to an auto elec but thanks anyways
