Latest: Mr-Koekwaus
Overall: 17125
Online Now [105]:
Visitors: 104
Today: 3065
Total: 99362831
Forums › The Car › 206 Talk › Front Suspension - Compression?
Triggerfish
PostPosted: Wed Sep 03, 2014 8:15 am Up
When you install new shocks and springs, do you need to "compress" the springs after installation?
My front suspension appears to be on the high side. The gap between the tyre and wheel arch appears wider in the front than the rears.
If it cannot be compressed, then I must have been advised the wrong springs.
Only the front shocks and springs have been renewed. The rear ones are existing.
Anyone got any advice?
206: 1.1L, 2002.
PostPosted: Wed Sep 03, 2014 10:39 am Up
So both your shocks and spring are new?
where did you get them from?
badj
PostPosted: Wed Sep 03, 2014 2:40 pm Up
I've found that you normally need to let them settle.
Additionally, did you leave the shocks off the car for a day or more?
Iceland Blue '99 206 GTI (140) - SOLD
KMF '05 1.4 HDi
Triggerfish
PostPosted: Wed Sep 03, 2014 5:40 pm Up
Yes, both front shocks and springs are new.
ECP.
206: 1.1L, 2002.
Triggerfish
PostPosted: Wed Sep 03, 2014 5:46 pm Up
Well that's what I thought, let them settle but they don't really come down.
Do you mean the built up shock and springs with top and bottom mounts as a complete built unit.....left for one day or more before mounting into the car.....then, yes. Max 2 day, no more.
206: 1.1L, 2002.
PostPosted: Thu Sep 04, 2014 6:30 am Up
They might have supply you the wrong spring. Did you have the parts number from ECP?
You should not see much settlement for the suspension.
And are you sure you don't have several tones of bricks in the boot?
Triggerfish
PostPosted: Thu Sep 04, 2014 12:56 pm Up
Have been in contact with ECP and they confirm it is the right ones for the car.
ECP are looking into it.
No, no bricks, empty at the back.
206: 1.1L, 2002.
PostPosted: Thu Sep 04, 2014 12:58 pm Up
Have you actually measured the gap / ride height to see if its within spec?
PostPosted: Thu Sep 04, 2014 1:15 pm Up
www.peugeotlogic.com/w...ign206.htm
In case you ask what is the stock height
Triggerfish
PostPosted: Thu Sep 04, 2014 4:32 pm Up
So according to the guide:
Engine: TU1JP: manual gearbox with power steering.....which is "type 1 vehicle"
Front ride height (H1) should be 123mm.
Rear ride height (H2) should be 123mm.
(The front reference height H1, the rear is H2 and is measured between the road and the respective jacking point.)
Am I reading this correctly?
206: 1.1L, 2002.
Triggerfish
PostPosted: Fri Sep 05, 2014 3:45 am Up
Just measured the car:
(H1) Front ride height is 210mm.
(H2) Rear ride height is 210mm.
206: 1.1L, 2002.
Leegsi
PostPosted: Fri Sep 05, 2014 4:53 am Up
Just measured mine and its the same front and back:
PostPosted: Fri Sep 05, 2014 7:00 am Up
It must be like driving a Chelsea tractor. You did measure from the jacking point to the ground?
Triggerfish
PostPosted: Fri Sep 05, 2014 8:11 am Up
Yes, on a level ground. Directly from jacking point to ground for both front and rear wheels.
It is high isn't it....mmmmm.
206: 1.1L, 2002.
Triggerfish
PostPosted: Fri Sep 05, 2014 8:17 am Up
Looks like you too have a wide gap between top of tyre to wheel arch too.
But your tape measure is from wheel arch to centre of wheel. (approx 350mm)
If you zoom out of the picture, so you can see the jacking points. Can you measure the height from the jacking point directly down to the ground?
What do you have?
206: 1.1L, 2002.
