Latest: sparrowdclxvi
Overall: 17139
Online Now [564]:
Visitors: 563
Today: 142336
Total: 112953786
Forums › The Car › 206 Talk › Front Suspension - Compression?
Go to page Previous  1, 2
PostPosted: Fri Sep 05, 2014 8:21 am Up
Can't understand why the back is so high if only the fronts were changed.
Sounds like the new parts have either been supplied wrong or been assembled and fitted wrong wrong.
If you still have the original packaging, get the part numbers from it and ask the supplier to double check the part numbers. You never know, they might have given you springs for a diesel and the TU1 lump won't be heavy enough to compress them.
I don't suppose you have tried a bounce test on the front. Just open the bonnet and push down on the strut tops to see if you can get the suspension to move any.
One thing we don't know yet is what wheel and tyre size combination do you have?
Triggerfish
PostPosted: Fri Sep 05, 2014 10:37 am Up
Had a thought about that too but it sits ok, the gap between tyre and rear wheel arch is perfect/ideal.
I do remember that before the front shocks & spring were changed, the front (H1) were lower than the rears(H2) and the gap between tyre/wheel arch is the same.
Tried that already but stays the same.
I have a thought, see what you guys think? I want to detach the ARB drop links (both sides) from the suspension struct and let the car rest on the front wheels so to let the front natural weight rest on the springs to compress it down. Let it rest for a day....or more.....and see what happens.
Wheels/tyres are 205/40 ZR17 to both front and rears.
206: 1.1L, 2002.
Triggerfish
PostPosted: Sun Sep 07, 2014 5:57 am Up
Right, took the ARB drop links out, let the car rest on the shocks and springs, it is still in the same position.
This confirms to me the springs are too big/wrong as the springs are the only element that is holding up the front of the car.
Need to wait from ECP / supplier to see what they say.
206: 1.1L, 2002.
badj
PostPosted: Sun Sep 07, 2014 4:50 pm Up
Just out of interest, have you considered the possibility that the car will sit like a monster truck on 17's anyway, with standard suspension, if its a 1.1?
Iceland Blue '99 206 GTI (140) - SOLD
KMF '05 1.4 HDi
Leegsi
PostPosted: Sun Sep 07, 2014 4:59 pm Up
Measure from the arch to the centre of the wheel and see what that is.
If your running 17's and standard suspension it will be high.
Triggerfish
PostPosted: Mon Sep 08, 2014 6:32 am Up
No, no need now, it is reality.
It measures a MASSIVE 405mm!!
So is it fair to say, the car had lowered springs before.
Looks like I need to lower 67mm to equal the rears.
So can I get a 60mm spring reduction on a standard shock?
206: 1.1L, 2002.
badj
PostPosted: Mon Sep 08, 2014 12:43 pm Up
Of course..
Laughing
Seriously though, you can get the springs:
www.ebay.co.uk/itm/Peu...0712888756
But it's odds on to c**k up standard shocks later on
KMF '05 1.4 HDi
Page 2 of 2
