Latest: williamekstrom
Overall: 17124
Online Now [104]:
Visitors: 103
Today: 10752
Total: 99342781
Forums › The Car › 206 Problems › oil in the Expansion bottle 206 1.4 petrol engine
spanielsam
PostPosted: Mon Sep 15, 2014 6:11 am Up
Hello
I wonder if anybody can give me some advise please, we have had a 2003 206SW 1.4 petrol engine for a number of years and it has done 70,000 miles now . The cam belt and water pump were changed at 50,000 miles.
We now have a problem with the expansion bottle become severely contaminated with oil. But strangely there does not appear to be any contamination in the coolant in the radiator or in the engine, we have drained this out and it looks fine ?
The car is running well and not overheating and there is no sign of any white sludge in the oil filler cap area. The car is not loosing any water.
We have cleaned the expansion bottle out and the oil starts to reappear within 100 miles
I am assuming that this can only be a cylinder head problem but am confused by the lack of overheating and no water in the oil.
Is there any other way oil can get into the expansion bottle ?
Can oil get from the oil cooler into the water radiator - clutching at straws here !
Apologies for the long post !
Vexs
PostPosted: Mon Sep 15, 2014 10:39 am Up
I'm afraid it's most likely a head gasket leak, very common problem with these engines and you have the exact same problem I had went mine had a slight leak.
Take it to a garage and have it checked before you do start to have overheating issues
My GTI 180
My Old 1.4 8v
PostPosted: Mon Sep 15, 2014 2:22 pm Up
Automatic or Manual Gearbox?
spanielsam
PostPosted: Mon Sep 15, 2014 3:30 pm Up
Hi
It is a manual gearbox
The car did 180 miles today and the expansion bottle is about 50% oil but it did not overheat or misbehave ?
PostPosted: Tue Sep 16, 2014 4:49 am Up
Headgasket failure, do it before you cant get the oil out of the system
spanielsam
PostPosted: Tue Sep 16, 2014 8:21 am Up
Thanks for your replies , car booked in the garage for Thursday, thought about doing it myself but never touched a timing belt and especially retensioned one , so £400 it is then !
