Online Now [922]:
Visitors: 921
Today: 112959
Total: 155409490
Forums › The Car › 206 Problems › Just gained 10% more throttle on my 180
mattymj
PostPosted: Fri Sep 19, 2014 8:42 am Up
After looking through my PP2000 i noticed my throttle would only goto 90% when pushed to the floor
Tracked the problem to the accelerator pedal.
Tried 2 option which both worked.
1. Remove the accelerator pedal and place two washers on each thread.
2. Remove the accelerator stop plug
Hey presto
Have yet to drive it as was in a rush.....
Can anyone see any problems with this gain?
PostPosted: Fri Sep 19, 2014 1:07 pm Up
Can't see the point really as even at motorway speeds you're unlikely to have your foot to the floor.
mattymj
PostPosted: Fri Sep 19, 2014 1:51 pm Up
I thought 100% would equal more performance than 90% more air more fuel etc
PostPosted: Fri Sep 19, 2014 2:37 pm Up
That's if the throttle body at 90% is a restriction. The engine might be consuming as much air as it can even at 90% throttle.
mattymj
PostPosted: Fri Sep 19, 2014 3:48 pm Up
I guess it could be but every little helps. Would the ecu alter the fuelling between the % difference?
PostPosted: Sat Sep 20, 2014 7:44 am Up
Yes it would, I don't see any negative issues occurring.
mattymj
PostPosted: Sat Sep 20, 2014 10:09 am Up
Well I have popped the grommet back in the carpet and the pedal is registering 90% again when floored, I have been looking in my PP2000 menus to recalibrate the system but can't see an option, I tried resetting the auto adaptives but at no point did it say to floor the accelerator!!
Is there something I am missing as there are hundreds of menus on the program
Any help appreciated
PostPosted: Sat Sep 20, 2014 11:07 am Up
Does the throttle butterfly open and move without the engine running? That's great best way of measuring whether there's any benefit.
Maqer
PostPosted: Tue Sep 23, 2014 8:17 pm Up
Mine shows 94% or 95% but I'm getting sub 7's 0-62 acceleration so I don't think it matters much. I'm not sure that it's accurate representation of the gas pedal position. Maybe a movement range that the pedal has? But still at the whatever % you get the ecu is giving full acceleration? It's pretty smart and calibrates the throttle butterfly and pedal.
You can do the calibrations manually too, check the how-tos.
jauraari @ gmail.com
gpvecchi
PostPosted: Wed Sep 24, 2014 2:45 pm Up
You can recalibrate butterfly inside ECU parameters with PP2000; but I think this is useless, as throttle just follows 10% steps, you'll see 90% but it could be 99%; when calibrating butterfly you have to set the pedal from full lift off to full down, and this is paired with butterfly. So, if butterfly opens 100% (you can see it with key on and engine off), everything is ok.
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
