Latest: sparrowdclxvi
Overall: 17139
Online Now [164]:
Visitors: 163
Today: 37796
Total: 113237699
Forums › The Car › 206 Problems › Can I stop my brakes squeaking?
JordHaze
PostPosted: Fri Sep 19, 2014 9:11 am Up
Hey,
Self explanatory, How do I do it?
Cheers,
Jord
My 206 Project Thread
commandosqueak
PostPosted: Fri Sep 19, 2014 9:28 am Up
Clean up breaks and grease up the slider pins and shims
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
PostPosted: Fri Sep 19, 2014 2:17 pm Up
Use Carb. Cleaner (same as brake cleaner),this usually help with squeaking,and you need to clean the pins that move the caliper when you push the brake pedal,with silicone grease.
PostPosted: Sun Sep 21, 2014 5:28 pm Up
Strip, remove corrosion, lubricate metal to metal contact faces with copper or silicon grease. Get a knowledgeable mate to show you.
