Latest: ArtistKS
Overall: 17145
Online Now [132]:
Visitors: 131
Today: 11259
Total: 115952210
Forums › The Car › 206 Problems › front wheel noises
front wheel noises
Razor34
PostPosted: Sat Sep 27, 2014 5:42 am Up
Hi,
I have a 206 1.4 GLX 02 plate and for the last month seem to be having a squeaking noise coming from the passenger front wheel. It basically seems to be constant when at low speed say 10mph and disappears briefly if brake pedal replaced. It also always happens when turning the steering slightly left but nothing when going right. It has been in my local garage but they cannot seem to find the problem. Brake discs and pads have been replaced and also droplinks both sides and noise is still occurring.
Any ideas or anyone local to Croydon who can diagnose for me as driving me nuts and do not want to spend much more on it.
Ray
gd_85
PostPosted: Sat Sep 27, 2014 9:06 am Up
Wheel bearing? Can you Jack the one side up and give it a spin? Shouldn't hear much noise from it if all good.
Razor34
PostPosted: Sat Sep 27, 2014 9:28 am Up
Hi I was told wheel bearings ok
Ray
Razor34
PostPosted: Sat Sep 27, 2014 12:39 pm Up
Wheel bearings checked and all ok?
Ray
gd_85
PostPosted: Tue Sep 30, 2014 2:51 am Up
Hmmm... Bushes? Or a broken spring?
magistar
PostPosted: Tue Sep 30, 2014 3:00 pm Up
try jack the car up and spin the wheels to see if you can identify where the noise is coming from. try remove the wheel and have a play around too.
Try have a look at the wheel hub nut/cap and pin in case if it is loose and rattles.
Razor34
PostPosted: Wed Oct 01, 2014 1:52 am Up
Thanks will have a look
Ray
