Latest: williamekstrom
Overall: 17124
Online Now [107]:
Visitors: 106
Today: 10765
Total: 99342794
Forums › The Car › 206 Problems › Anti pollution Fault
tomsk14
PostPosted: Mon Sep 29, 2014 12:30 pm Up
Okay so I know this is complicated but I will do my best.
This is much more likely to happen when the car is cold, and when I try to turn it over it just 'chokes' and wont actually start. I take the key out, try again and it starts. Always on second attempt. The oil level shows it is empty/almost empty (when this problem doesnt occur the oil level shown is fine and the oil level IS fine) and then the engine diagnostic light appears and the beep noise accompanied by ' anti pollution fault'. It also appears to be affecting whether I can get hot air out of the car? This is also intermittent though.
I have had it looked at at a local garage, who put it on the diagnostic and said they believed it to be the ignition coil pack - I paid £200 and it hasnt fixed it.
However before I had this done, when the above 'happened' the car would lose power as well, I havent had that hapen since the ignition coil was fitted about 2 months ago.
I have a full warranty on it including cat convert. cover if needed, my problem is the garage(s) will not do the work unless they are sure as they believe they wont get paid if they fix the wrong bit.
I also had it diagnosed a second time and they said it was simply showing something as being wrong with the computer on the car.
I have given as much detail as I possibly can, but my car is a 2005 206cc 2.0l with only 40k on the clock and in beautiful condition otherwise - I'd really like to get this problem fixed esp. whilst its still under warranty - another 3 months.
Any ideas?
Thanks so much. Really appreciate any help.
mattymj
PostPosted: Mon Sep 29, 2014 12:50 pm Up
Best get it plugged into Peugeot planet software. Where r u based?
tomsk14
PostPosted: Mon Sep 29, 2014 2:31 pm Up
Near Ipswich in Suffolk - What do I need to do?
mattymj
PostPosted: Mon Sep 29, 2014 3:50 pm Up
Well if u can get to me i will plug it in and do a full car scan.
Im in Norfolk near Norwich
tomsk14
PostPosted: Mon Sep 29, 2014 4:02 pm Up
Will that pin down the problem properly though? and how much will that be please? thank you.
mattymj
PostPosted: Mon Sep 29, 2014 4:09 pm Up
Its a very thorough way of checking, its what the dealers use.. I would like to hope it would pin-point the problem. It won't cost much...
tomsk14
PostPosted: Mon Sep 29, 2014 4:11 pm Up
Can you tell me what not much is? If its your own equipment? Coming to Norwich is no issue..
PostPosted: Wed Oct 01, 2014 9:12 am Up
If the garage attempting to fix it are the selling garage then fault diagnosis and repair is their problem. If the warranty is sold seperately then that might be a bit more difficult.
Warranties...........
mattymj
PostPosted: Sun Oct 05, 2014 4:07 pm Up
Id like to hope so, only charge a tenner
