Latest: sparrowdclxvi
Overall: 17139
Online Now [195]:
Visitors: 194
Today: 10157
Total: 113458573
Forums › The Car › 206 Problems › pp2000 install issues
Go to page Previous  1, 2, 3, 4
PostPosted: Thu Oct 02, 2014 12:25 pm Up
Have you cleared all the values in the registry (regedit) with referencing to the lexia / pp2000?
Here's an installation guide - nwex.co.uk/downloads/p...nstall.pdf
Update guide - nwex.co.uk/downloads/p...Update.pdf
Activation guide - nwex.co.uk/downloads/p...vation.pdf
PostPosted: Thu Oct 02, 2014 12:31 pm Up
commandosqueak wrote:
Cheers I will have a look! I did install diagnosed but it wouldn't work! It installed fine but then would connect to anything
Your Lexia / Evolution interface needs to be flashed to revision C if your using Diagbox version 7.00 or newer Wink
commandosqueak
PostPosted: Fri Dec 19, 2014 9:07 am Up
Still haven't got this working, took a break from it as it was driving me nuts. anyone have any suggestions. going to reread the thread and retry everything on Monday.
If i don't get it working is there anyone that has pp2000 in Gloucester or where i live in the Cotswold's that could plug me in and change the optics so i can finally fit my new lights?
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
206gt160
PostPosted: Fri Dec 19, 2014 10:04 am Up
Sorry for jumping in the thread, but does anybody know whether or not on when it says ECU unlocked on pp2000 if that means that the immobiliser is off and not immobilised?
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
Page 4 of 4
