Online Now [504]:
Visitors: 503
Today: 101156
Total: 154792542
Forums › The Car › Request a how-to › Remove the Hub assembly 206
ishmael123
PostPosted: Sat Oct 04, 2014 11:10 am Reply with quote Up
Straggle to remove a front lower ballpoint of 206, model 2006 to able to remove hub assembly
gazza82
PostPosted: Sat Oct 04, 2014 11:55 am Reply with quote Up
I use a long piece of 4x2 (hardwood). One end under floor, over the arm and sticking out under bumper ... and stamp on it Smile
PostPosted: Sat Oct 04, 2014 12:37 pm Reply with quote Up
I just undo the lower bolt and push down on the wishbone with my foot
AWK-53
PostPosted: Sun Oct 05, 2014 6:04 am Reply with quote Up
Same as Edward says
gazza82
PostPosted: Sun Oct 05, 2014 5:50 pm Reply with quote Up
Depends how long old ones have been on Smile
Also may need to slightly open up gap where clamp bolt goes. They get overtightened and hold on
uttz
PostPosted: Mon Oct 06, 2014 7:29 pm Reply with quote Up
loosening the subframe bolts helps also, not all the way but enough to drop it a little lower
GTi 180 Obsidian Black
SW 1.6 16v Sahara Yellow
  Quick Reply
Username:
Message:
Quote the last message
