Posted: Thu Mar 20, 2014 3:38 pm |
Looking for some uprated exhaust rubbers for my 180 as one mine have snapped but want to stop the sagging that cones with OEM rubbers
Iv read around that powerflex are good but don't get certain model number :/
| Image removed due to size | |
Posted: Thu Mar 20, 2014 4:46 pm |
Mate check out superpro, got them on mine
Posted: Thu Mar 20, 2014 4:48 pm |
MattyP wrote: |
Mate check out superpro, got them on mine |
Cheers dude will get on it now
Posted: Tue Oct 07, 2014 7:48 am |
Just ordered some for the 206CC from upratedbushshop and before I had time to print the order they came back to say they had been despatched direct from Superpro!! That's what I call service .. £32 for three with free P&P.
Try modworld first and they simply refunded saying no stock and also had TDC Performance as plan B who confirmed they had them but at about £5 more.
Shall be fitting new exhaust and bushes later this month ... and I'll update you all again then. Reason for fitting them is to try and get exhaust up a bit higher as it has already been bent, and split the centre box, on a speed-bump!
Posted: Thu Nov 13, 2014 12:08 pm |
Didn't use rear ones in the end as I couldn't be ar##d to take the back box off the CC. I did use the front one and seems a lot firmer. Time will tell ...
So will put the rear pair on the 1.4 which has just dropped the rear box ... front pipe snapped off just after the clamp.Hoping replacement arrives as promised tomorrow.
