Latest: williamekstrom
Overall: 17124
Online Now [203]:
Visitors: 202
Today: 29421
Total: 99321251
Forums › The Car › 206 Problems › Temp gauge
Temp gauge
lip_88
PostPosted: Tue Oct 14, 2014 3:05 pm Up
Trying to find the fault with my temp gauge on my gti it will read for about 10 seconds then drop back to 0 if you restart the engine it does the same so where should I be looking at starting
PostPosted: Tue Oct 14, 2014 4:52 pm Up
Which temp gauge?
A GTI has both coolant temp & also oil temp gauges.
lip_88
PostPosted: Wed Oct 15, 2014 3:39 am Up
Oil temp gauge
PostPosted: Wed Oct 15, 2014 11:11 am Up
Most likely a faulty sensor.
Guessing from the fault description we are talking non plexed 206.
Adam1973
PostPosted: Wed Oct 15, 2014 1:44 pm Up
Hi, I have a non plexed 206 1.4, my oil temp gauge does the level check when start engine, but then goes back to bottom and stays there... Even after a long run.
lip_88
PostPosted: Wed Oct 15, 2014 1:45 pm Up
I believe it is a pre plexed model yes mate
PostPosted: Wed Oct 15, 2014 1:47 pm Up
Has someone fitted the wrong oil probe?
Choice of 2 for the TU3 engine & only 1 of them does oil temp.
Adam1973
PostPosted: Thu Oct 16, 2014 11:14 am Up
Not sure as to if wrong oil... The gauge just does not move at all once done the level check. How you mean "Choice of 2 for the TU3 engine & only 1 of them does oil temp."???
PostPosted: Thu Oct 16, 2014 11:24 am Up
There are 2 oil probes listed for the TU3 engine.
One probe only does oil level.
The other probe does oil level & oil temperature.
Adam1973
PostPosted: Fri Oct 17, 2014 1:16 pm Up
Hmm ok, got ya thanks... I'll have to look and see. Any idea as to how to tell which I have and if it's just faulty??
PostPosted: Fri Oct 17, 2014 1:22 pm Up
One has a 22mm hex & the other has a 24mm hex, cant remember which way round it is, been a few years since I last had one removed.
