Posted: Tue Oct 14, 2014 3:05 pm |
Trying to find the fault with my temp gauge on my gti it will read for about 10 seconds then drop back to 0 if you restart the engine it does the same so where should I be looking at starting
Posted: Tue Oct 14, 2014 4:52 pm |
Which temp gauge?
A GTI has both coolant temp & also oil temp gauges.
Posted: Wed Oct 15, 2014 3:39 am |
Oil temp gauge
Posted: Wed Oct 15, 2014 11:11 am |
Most likely a faulty sensor.
Guessing from the fault description we are talking non plexed 206.
Posted: Wed Oct 15, 2014 1:44 pm |
Hi, I have a non plexed 206 1.4, my oil temp gauge does the level check when start engine, but then goes back to bottom and stays there... Even after a long run.
Posted: Wed Oct 15, 2014 1:45 pm |
MrBSI wrote: |
Guessing from the fault description we are talking non plexed 206. |
I believe it is a pre plexed model yes mate
Posted: Wed Oct 15, 2014 1:47 pm |
Adam1973 wrote: |
Hi, I have a non plexed 206 1.4, my oil temp gauge does the level check when start engine, but then goes back to bottom and stays there... Even after a long run. |
Has someone fitted the wrong oil probe?
Choice of 2 for the TU3 engine & only 1 of them does oil temp.
Posted: Thu Oct 16, 2014 11:14 am |
Not sure as to if wrong oil... The gauge just does not move at all once done the level check. How you mean "Choice of 2 for the TU3 engine & only 1 of them does oil temp."???
Posted: Thu Oct 16, 2014 11:24 am |
Adam1973 wrote: |
How you mean "Choice of 2 for the TU3 engine & only 1 of them does oil temp."??? |
There are 2 oil probes listed for the TU3 engine.
One probe only does oil level.
The other probe does oil level & oil temperature.
Posted: Fri Oct 17, 2014 1:16 pm |
Hmm ok, got ya thanks... I'll have to look and see. Any idea as to how to tell which I have and if it's just faulty??
Posted: Fri Oct 17, 2014 1:22 pm |
Adam1973 wrote: |
Hmm ok, got ya thanks... I'll have to look and see. Any idea as to how to tell which I have and if it's just faulty?? |
One has a 22mm hex & the other has a 24mm hex, cant remember which way round it is, been a few years since I last had one removed.
