Online Now [293]:
Visitors: 292
Today: 121938
Total: 154931151
Forums › The Car › 206 Talk › central locking
central locking
Forum Index › 206 Talk
sean.r.steward
PostPosted: Fri Oct 17, 2014 6:39 pm Up
Hi all, the car in question is a 206 cc 1.6 2002. The central locking is not working correctly. As far as I have got with diagnosing it, the car is recognising the key. Bsi is making a relay click via a press on eather button on the key. But the door locks are not energising The cars doors and boot is locking and unlocking via button on the dash. I have reset the bsi 3 times now, checked 2 fuses(fuse data from autodata).
I have no experience of peugeot planet. Is there any capabilites with it for central locking, ie activation of diagnosis
sean.r.steward
PostPosted: Sat Oct 18, 2014 7:50 am Up
does anyone have peugeot planet in ipswich area?
sean.r.steward
PostPosted: Sun Oct 19, 2014 4:54 am Up
this is a bit quiet
PostPosted: Sun Oct 19, 2014 6:05 am Up
Did you check the forum Peugeot Planet map for members nearby with Planet?
www.206info.co.uk/Foru...55053.html
sean.r.steward
PostPosted: Sun Oct 19, 2014 9:24 am Up
Yer there is a bloke in Norwich. I might aswell invest in getting it myself as the misses has a cc and I have a gti. Is the Chinese clone no good?
PostPosted: Sun Oct 19, 2014 9:32 am Up
Unless you get the interface from a Peugeot / Citroen main dealer OR Actia directly there all going to be a clone of some kind.
Try & get an interface already running revision C firmware, not important for a 206 but a bonus if in the future you want to plug in to newer PSA products.
sean.r.steward
PostPosted: Sun Oct 19, 2014 11:38 am Up
ok brill thank you, i just had it plugged into a snap-on but i knew it wasn't going to get into the central locking. but the bloke was nice anuff. he wasn't after any money. he did say if it was a newer peugeot it would have a bigger chance getting into the central locking system.
