Latest: sparrowdclxvi
Overall: 17139
Online Now [152]:
Visitors: 151
Today: 38214
Total: 113527489
Forums › The Car › 206 Problems › 2.0 hdi lumpy idle + stalling
Nath189
PostPosted: Wed Oct 22, 2014 5:54 am Up
Hi all over the past two days had this fault with my car, it's when I'm pulling up to stop in traffic or at lights. the revs start bouncing down juddering the car and stalling it. It only starts to happen once it warmed up. Anyone had this before?
In the last 3 months it's had a coolant temp sensor so can't see it being that. I did put a cone air filter on on Sunday but took it off last night thinking it was sucking to much air. And changed the aux belt to a smaller one due to air con pump bearings whining. Any help would be appreciated.
Baggiesfan01
PostPosted: Wed Oct 22, 2014 7:14 am Up
HI i had a similar issue it was the fuel pump regulator. My car did exactly the same i had it changed and it solved it.
I would start it up it from cold it would be OK then second set of traffic lights or third it would start with the revs jumping then cut out. took it to my mechanic and he changed the fuel pump regulator and it sorted it sadly it was a recon part he used so had to have another one a few months later.
Pug 2.0 HDI owner
Nath189
PostPosted: Wed Oct 22, 2014 7:34 am Up
Hi baggiesfan (great team aha) thanks for the info I'm getting put on the snap on machine at my mates work tonight so hopefully ill find where the fault Lyes.
Baggiesfan01
PostPosted: Wed Oct 22, 2014 7:35 am Up
Hope it helps it may not be that with yours but as i say sounds very similar to my issue.
Pug 2.0 HDI owner
Ciaran996
PostPosted: Wed Oct 22, 2014 5:02 pm Up
I had the same problem also the clutch wasnt engadging some times aswell turn out it was the fuel pump
Nath189
PostPosted: Wed Oct 22, 2014 5:49 pm Up
I had a look at the live data reading and the fuel pressure drops when the engine is juddering. As I've had the car a year and no real detail in the service history, i start with a filter then pressure sensor and so on cheers for the help guys
