Latest: lio94
Overall: 17181
Online Now [326]:
Visitors: 325
Today: 79787
Total: 141834336
Forums › The Car › 206 Talk › Using cheap coil packs from Lada on peugeot 206 TO TRY !
MUHAMED
PostPosted: Sun Oct 26, 2014 2:55 pm Up
I think that this is a good solution instead of buying expensive coil packs for 206 (they are here about 140 EUR - original) but those ones for Lada are only 60 EUR (at the dealership).
Also you will need spark plug cables from Lada 1.5 / 1.6 8 valve engine.
How the russians managed to fit Coil pack from Lada to a Renault engine (3 pin connector). It may be possible for 206 too. I believe that is worth to try. Maybe from other car it can be fitted too..
This is about K4M from Renault. Information is on russian. Use google translate to translate it.
ac-diagnostic.ru/publ/...z/1-1-0-28
Barking
PostPosted: Sun Oct 26, 2014 2:59 pm Up
We don't have Lada dealers in the UK - haven't since 1997 Laughing
I got a dig bick.
You that read wrong.
You read that wrong too.
MUHAMED
PostPosted: Sun Oct 26, 2014 3:07 pm Up
Maybe it can be used from another car. Those are really cheap. You can order them online.
This is a Bosch number of coil pack for Lada 8V engines.
prntscr.com/501cjg
Also Fords have same Coil packs 4 outputs 3 contacts...
prntscr.com/501h06
And here is schematic for Peugeot 206
prntscr.com/501hjn
This makes me thinking that you can easily use Ford coil pack too. Just you need to buy spark plug cables. And coil pack for Ford is much more cheaper as I believe.
Here russians are using cheap coil packs for Opel / Vauxhall engines. Also method is working 100%.
www.vectra-club.ru/for...0&t=136949
(there are pictures and use google translate to read threads)
gazza82
PostPosted: Mon Oct 27, 2014 2:53 pm Up
You'll need very long plug connectors ... they are deep in the engine hence the long connectors on the proper coilpack.
MUHAMED
PostPosted: Tue Oct 28, 2014 4:42 pm Up
yes correct. But I believe that it can be done. Also russians say that coil packs from Hyundai are best alternative since they are much more reliable. Worth thinking.
