Latest: DanDan17
Overall: 17128
Online Now [43]:
Visitors: 42
Today: 10177
Total: 100437894
Forums › The Car › 206 Problems › Anti-Pollution Fault
declfc
PostPosted: Tue Nov 11, 2014 12:32 pm Up
Hello, I was wondering if I could get some advice.
My car Peugeot 206 HDi GTi 110 – 111000 Miles
Last week I was driving home from work and my engine management light came on with the alarm “Anti-Pollution Fault” on the display screen. The car went into “limp” mode and I very slowly drove it home.
I booked it into a garage for them to take a look at. But 48 hours later I got in it and went to drive it to the garage and the fault had gone, no alarm in the display and engine management light was off. Car drove fine.
I took it to the garage the put it on the diagnostics and the only fault they found was a fuel pressure one, which he cleared, charged me £40 and I went on my way!
One week later the car has done the same again. Engine management light is on and only driving in “limp” mode.
Not sure what to do now?
Any ideas?
Thanks for taking a look.
mtempsch
PostPosted: Tue Nov 11, 2014 12:50 pm Up
It's a very general 'catch all' error message. Without error codes it'll be tricky...
Back when I got my then brand new RC / GTi180 it went into limp mode with this message on, IIRC, day 4, then spent almost 3 weeks at the dealer/shop. Picked it up twice "fixed" - first time I got about 12km before the error returned, 2nd time only about 800m.
Apparently (what they said) it was an intermittent connection in a connector, due to one of the contact pins not being fully inserted / locked into the plug. No idea which though...
Silvermetallic 2004 206 RC
cartoonhead
PostPosted: Tue Nov 11, 2014 1:05 pm Up
ahhh the 1.6 HDi , the worst engine to be fitted to the 206 Wink
PostPosted: Tue Nov 11, 2014 1:15 pm Up
Needs scanning for fault codes for a start.
How long you had the car?
declfc
PostPosted: Tue Nov 11, 2014 1:16 pm Up
Just over a year.
declfc
PostPosted: Tue Nov 11, 2014 1:17 pm Up
It was scanned, came back with a fuel pressure fault, which the guy cleared.
mtempsch
PostPosted: Tue Nov 11, 2014 1:18 pm Up
What about a fix of what actually caused the error to be logged?
declfc
PostPosted: Tue Nov 11, 2014 1:19 pm Up
Well yeah, but what caused the error?
declfc
PostPosted: Tue Nov 11, 2014 3:42 pm Up
Ok its been recommended by a friend that I change the in-line fuel filter first. (had the fuel pressure fault) How does this sound?
Lecktorious
PostPosted: Tue Nov 11, 2014 4:52 pm Up
Trade Rating: +59
Questionable as the fuel filter isn't in-line!
I reckon you have a problem with the DPF system, although it will be hard to tell exactly where until the fault returns.
'98 Nile Blue 306 GTi 6
declfc
PostPosted: Tue Nov 11, 2014 5:10 pm Up
The fault is back again right now. I bought one of those OBD2 Bluetooth diagnostic scanners today but left it at work, so in the morning I will do the scan and see what faults it comes back with.
Hopefully fault will still be there in the morning.
gazza82
PostPosted: Tue Nov 11, 2014 6:01 pm Up
if that reads it ... OBD2 might not work depending on age of car ...
206HdiGti
PostPosted: Wed Nov 12, 2014 6:04 am Up
I had my DPF removed and I still occasionally get the anti pollution message.
I believe there is a sensor either on or around the fuel cap area. If this isn't working properly it brings up the message, that's what I found when mine came on and we plugged it into my mate's snap-on computer.
Mine didn't go into Limp Mode though with that error message.
PostPosted: Wed Nov 12, 2014 11:30 am Up
The fault / faults will be safely stored in the ECU memory Laughing
You would be better of getting it scanned with Peugeot Planet.
pro_steve
PostPosted: Thu Nov 13, 2014 4:37 am Up
Anti pollution covers just about everything. AFter having the codes cleared last time when you scan this time around you'll know that whatever is there is the current fault.
If there is a fuel system fault then you will need to sort this out. You'll need to do some live diagnostics under load to figure out if the fuel system is under pressurising or over pressurising. Take the pressure regulator out of the pump and give this a clean, usually this will cause faults like this, or potentially a dodgy remap if you've had one done at all?
www.hdi-tuning.co.uk
