Online Now [486]:
Visitors: 485
Today: 134915
Total: 156849756
Forums › The Car › 206 Problems › pink wire under bonnet fuse box gti 180
Project2062014
PostPosted: Wed Nov 12, 2014 12:47 pm Up
Anyone got a wiring diagram of a 206 180 ?
Looking under the bonnet at the fuses . ive come across a pink wire thats been cut .it sits in the block connector .
The wire has been attached to a another cable .
it runs under the window back left side of the engine bay .
I have no left side window power& no horn .
I cannot even find a horn front left grill ?
mtempsch
PostPosted: Wed Nov 12, 2014 12:52 pm Up
Wire colours are not a definite thing in Peugeots - can you see the codes (numbers) printed on the wires involved?
Silvermetallic 2004 206 RC
gazza82
PostPosted: Wed Nov 12, 2014 5:29 pm Up
Horns are usually on the drivers side, low down near lower grill, on 206. Not always easy to see from engine bay without removing the bumper.
PostPosted: Wed Nov 12, 2014 11:30 pm Up
Horn wiring is a weak point on 206, I've repaired 3 so far over the years.
Have fun getting the bumper of Rolling On The Floor Laughing
MrWhite
PostPosted: Thu Nov 13, 2014 5:30 am Up
those 2 b******s bolts from bumper/arch I snapped one and cut the other out grrrrr Evil or Very Mad
My 206 Project Thread
pro_steve
PostPosted: Thu Nov 13, 2014 6:35 am Up
Hold the horn down and then follow the sound, might help you find it. I thought mine was behind the front grill before I relocated it.
www.hdi-tuning.co.uk
PostPosted: Thu Nov 13, 2014 7:18 am Up
Cut a pair of the other day, there designed for easy assembly at factory.
Project2062014
PostPosted: Fri Nov 14, 2014 2:50 pm Up
I used a adjustable spanner on gti front bumper bolts square plates to hold from spinning was a job .
Cleaned threads wire brush wd40 and they spin lose all way so easy to install and remove again .
Dont think il have a job on 180 as it looks as if the bumper has been off recently .
will check this pink wire code tomorrow . Been busy as . Cheers peeps!
Project2062014
PostPosted: Tue Nov 18, 2014 5:14 am Up
Cannot see a code on the wire . Letters ?
PostPosted: Tue Nov 18, 2014 5:22 am Up
Get your eyes tested, you can see the code printed on the pink wire your hokding in the picture!
Project2062014
PostPosted: Tue Nov 18, 2014 5:53 am Up
The horn does not work .
where did you relocate it ? Engine bay ?
Project2062014
PostPosted: Tue Nov 18, 2014 5:55 am Up
Lol its been cut throu a code . Cannot make out what it was .
This is what i can read .
1ECE . That the code ? Can read ( f1 ) printed between the codes .
Project2062014
PostPosted: Wed Nov 19, 2014 12:16 pm Up
Anyone know how i can find out what this pink 1ece wire is for ?
Project2062014
PostPosted: Wed Nov 19, 2014 3:18 pm Up
Its for the bsi ?
Carlos_WR1
PostPosted: Thu Nov 20, 2014 3:18 am Up
Can you not just trace it through the pin number on the green block?
You can see where it was attached, surely the wiring diagrame for the green block would tell you what each pin controls/operates?
