Latest: slaapkonijn
Overall: 17169
Online Now [375]:
Visitors: 374
Today: 29064
Total: 128621803
Forums › The Car › 206 Problems › Peugeot 206 1.4 8v Oil leak/Head Gasket
conker1221
PostPosted: Sun Nov 16, 2014 2:53 pm Up
Hi Guys,
I have a ever so small oil leak on the cambelt side of my engine, you can see it's coming from around where the gasket is and reading online it seems a pretty common fault with the 1.4 8v engine.
So am I pretty sure I need a new Head Gasket, but I am wondering if anybody could give me advice on a reasonable price? Am I better off going to a peugeot garage etc.
I have been told by a friend that £300 would be reasonable.
Any advice would be greatly appreciated,
Thanks.
Vexs
PostPosted: Sun Nov 16, 2014 3:28 pm Up
I had mine done beginning of the year, £300 is a good price though. Make sure to enquire if it needs skimming as well.
My GTI 180
My Old 1.4 8v
Oafie
PostPosted: Sun Nov 16, 2014 5:13 pm Up
That seems a good deal if they include and head skim too,
might be a good idea to throw a new water pump and cambelt on it at the same time.
it's easier to do with the head off.
Oafie
PostPosted: Sun Nov 16, 2014 5:14 pm Up
I meant a head skim not and sorry.
I need some new glasses.
conker1221
PostPosted: Mon Nov 17, 2014 4:32 am Up
It had a new cambelt and water pump only three months ago! The leak started about a month ago.
I'll get some quotes and hopefully I can get around the £300 mark.
Cheers for the replies.
Oafie
PostPosted: Mon Nov 17, 2014 5:57 am Up
Typical! DOH!!!
PostPosted: Mon Nov 17, 2014 1:51 pm Up
Head gasket or maybe the rocker cover,better way to be sure,is to clean that area,and observe where the oil come from before you do any work.
PostPosted: Tue Nov 18, 2014 12:33 pm Up
1.4 8V rocker cover leak is quite common. Those gaskets get really hard and brittle and crack.
PostPosted: Tue Nov 18, 2014 12:36 pm Up
Rocker cover is easily warped as well if the fixings are tightened above there recommended torque setting.
Many a TU rocker cover has been ruined by people being to heavy handed on the tools when refitting it.
PostPosted: Tue Nov 18, 2014 1:35 pm Up
+1 to also check rocker cover gasket. Common failing. On the 1.4 8V these get really hard and crack.
copey
PostPosted: Tue Nov 18, 2014 4:03 pm Up
i paid £400 on my 2.0 hdi, inc the head being skimmed, new timing belt, water pump and pulleys
02 2.0 hdi d turbo
Oafie
PostPosted: Tue Nov 18, 2014 7:09 pm Up
cheap!
