Latest: slaapkonijn
Overall: 17169
Online Now [155]:
Visitors: 154
Today: 33790
Total: 128699460
Forums › The Car › 206 Problems › revs up to 3500 after start
kadarfelix
PostPosted: Tue Nov 18, 2014 9:00 am Up
My peugeout 206 1.1i starts fine idles , but after about 4 mins it revs up to 3500RPM only for about 10 seconds. After that its idle is fine. If I stop the engine after that , and start again rev up is repeated quicker. If i start it with warm motor than everything is fine, no rev up.
Have you got any idea?
PostPosted: Tue Nov 18, 2014 9:07 am Up
Need the year of your 206.
Early 1.1 have old fashioned mechanical throttle, later 1.1 have full electronic fly by wire throttle.
Need to know which throttle set up you have.
kadarfelix
PostPosted: Tue Nov 18, 2014 9:21 am Up
PostPosted: Tue Nov 18, 2014 9:31 am Up
Will be the older mechanical throttle set up then.
boozeman
PostPosted: Tue Nov 18, 2014 1:28 pm Up
Throttle body needs cleaning? Well this is what I think I've read somewhere the GT I'm buying does the same thing
GT
PostPosted: Tue Nov 18, 2014 1:38 pm Up
I would also try throttle body / ICV circuit as a starting point. there is a "how to" on here somewhere.
kadarfelix
PostPosted: Wed Nov 19, 2014 1:23 am Up
Every sensor are cleaned. I tried flow warm air, with hair dryer, into air inlet, than it does not rev up.
I tried flow cold air, with hair dryer, into air inlet, than it does not rev up.
