Latest: elelectricistadeMateo
Overall: 17127
Online Now [66]:
Visitors: 65
Today: 10230
Total: 100408438
Forums › The Car › 206 Problems › tick over when cold
tick over when cold
Go to page Previous  1, 2, 3
Oafie
PostPosted: Wed Nov 19, 2014 5:21 pm Up
Hi Mate, as long as the fit plug together ok if should be fine, whats the worst thing it's going to do? turn the eml light on?
try plugging them together before you pull the sensor out.
Oafie
PostPosted: Wed Nov 19, 2014 5:39 pm Up
I've just been outside to check the colour's on the plugs on my sensors and mine has green on the top sensor
and blue on the down wind sensor.
I,m not sure if it will give a proper reading if mounted in the manifold.
n17ele
PostPosted: Thu Nov 20, 2014 10:19 am Up
Hi I have fitted it and no error message, but car will still not tick over !!
Looking around and the green connection is for pre cat and blue is for connection after the cat.
I have spoke to a few people who say it makes no difference ? Anyone think different?
So to date, no EML light and no code, but no tickover.
Anyone have a match Smile
n17ele
PostPosted: Mon Nov 24, 2014 2:12 pm Up
Hi
Put car in for a peugeot diagnostic system which indicated the relay for the fan were not working. Managed to locate them and when went to remove them some of the connections had snapped off the relay, and the other wires had rotted back about 50mm ! Put new relays on and ------Diagnostic then came up with the MAP not working. Last straw now, a new MAP ordered. fingers crossed it will sort it. Can not be many more sensors on there !
n17ele
PostPosted: Thu Nov 27, 2014 1:55 pm Up
Put new MAP sensor in Very Happy
and
The same Sad
Still will not tick over. Lost now
n17ele
PostPosted: Fri Dec 12, 2014 9:38 am Up
Just changed the throttle body and removed all errors. It still will not tick over ! However if I remove the servo pipe it will. Is there any stops on the body for tickover adjustment or is it all done by ecu?
Oafie
PostPosted: Fri Dec 12, 2014 12:17 pm Up
on your's the tick over is controlled by a stepper motor which is on the back of the throttle body,
which is then controlled by the ecu.
n17ele
PostPosted: Sat Dec 13, 2014 4:08 am Up
I understand the tick over is controlled by the ECU, however if the ECU is receiving a signal from a sender that is not correct I think it will send wrong signal to the throttle body.
I have changed loads of things and it will still not tick over.
n17ele
PostPosted: Tue Jan 13, 2015 2:07 pm Up
Managed to get a 2nd hand throttle body, fitted and no difference. Still will not tick over when cold. It will tick over if I hold my foot on accelerator (it will tick over at any revs then). Once the temperature goes to normal tick over is ok.
Any more ides ? there is no stepper motor on this engine
I have changes the plugs, air filer, thermostat, temperature sender, fan relays ,throttle body and pre cat Lambda.
Car runs really nice once warm
Page 3 of 3
