Latest: williamekstrom
Overall: 17124
Online Now [112]:
Visitors: 111
Today: 15954
Total: 99347957
Forums › The Car › 206 Problems › LAMBDA SENSOR
LAMBDA SENSOR
n17ele
PostPosted: Thu Nov 20, 2014 6:32 am Up
Just trying to cure a tickover problem which could be the pre cat lambda sensor ?? I bought a second hand one and it has a blue connection, mine was green. Will this be ok, it will fit into the green connector block .
gazza82
PostPosted: Thu Nov 20, 2014 5:50 pm Up
It might fit but it might not work properly. The cable length is part if the circuitry ... so the wrong length can affect how it registers on the ecu.
PostPosted: Thu Nov 20, 2014 6:16 pm Up
Blue is the AFTER cat or downstream sensor. It WILL not work correctly at all
hamed206
PostPosted: Thu Nov 20, 2014 6:18 pm Up
I wouldn't fit it mate. Plugs color should be the same!
Hamed
