Latest: Andyblue64
Overall: 17123
Online Now [23]:
Visitors: 22
Today: 57452
Total: 98086796
Forums › The Car › 206 Problems › Poss Coil Pack Failure?
dazw30
PostPosted: Tue Nov 25, 2014 11:22 am Up
About 2 weeks ago had a problem with a 53 1.4 Quicksilver where MFD showed Anti-Pollution fault & engine was misfiring but then cleared itself & been fine since. Plugged in PP2000 today just to see what faults was recorded. Came up with "Intermittent fault ignition misfiring' & 'intermittent fault Adoption of the quantity of air entering the manifold'.
PP2000 then showed the fault can be caused by
-Damaged connection of harness
-Faulty Control Unit Calibration.
So does this mean Coil Pack faulty? or something else
DW & his 2004 Red 206 GTi 180
PostPosted: Tue Nov 25, 2014 6:15 pm Up
Personally, I would shove a set of plugs and coil pack on it and see how you go
Coil and plugs normally fix most things
dazw30
PostPosted: Tue Nov 25, 2014 8:12 pm Up
gaznandrea
PostPosted: Thu Dec 04, 2014 2:16 am Up
I have exactly the same symptoms as this changed both spark plugs and coil pack made no difference any other ideas cheers
black peugeot 206 gti 180 lowered all round morrette headlights smoked tail lights full cobra exhaust
