Posted: Fri Nov 28, 2014 11:20 am |
hi everyone just thought id ask you good people on how to replace the centre window/mirror controls?
ours decided to snap off in my hand last night
id imagine to existing one should just flick out and then replace with new unit ?
any tips appreciated
Posted: Fri Nov 28, 2014 12:05 pm |
The knob does come of the mirror switch if your heavy handed, sometimes it can be re attached if the shaft is still intact.
If it's a complete switch unit swop then:
Unclip it from the centre console then unplug the 2 connector plugs from the switch ( press down on the locking clips before attempting to remove the plugs ) it's not exactly rocket science.
HOWEVER: Make sure you get the correct part number switch as a replacement, there are MANY switches that lock exactly alike from the outside BUT are different inside ( even just on the 206 range! )
At best it wont work correctly, at worse it will pop the window fuse
Posted: Fri Nov 28, 2014 12:28 pm |
thanks alot for that i knew it wouldnt be rocket science just thought its best to double check.
oh iv done it properly lol
Posted: Sun Nov 30, 2014 6:41 am |
which switch do you have Andy. I have a second hand mirror switch in a GT with mirror park
