Posted: Sat Nov 29, 2014 3:43 pm |
Posted: Sat Nov 29, 2014 4:23 pm |
Nope and they don't look like Peugeot wheels.
Posted: Sat Nov 29, 2014 4:27 pm |
I'm sure i've seen other 206's with these wheels and it has the Peugeot hub caps.. Well on the other side at least. I'm assuming these came with steel wheels then?
Posted: Sat Nov 29, 2014 5:00 pm |
Servicebox tells you what the vehicle left the factory with. If it says in the characteristics that it left with steel wheels, then they may have been an option.
Those look very similar to mine which I believe are 14" Tornado allotys
Posted: Sat Nov 29, 2014 5:28 pm |
| macca1411 wrote: |
| Those look very similar to mine which I believe are 14" Tornado allotys |
They look identical to yours and they're 14" i believe and thanks i will check it out
Posted: Sat Nov 29, 2014 5:38 pm |
Servicebox won't load at all for me. Was thinking of contacting my local Peugeot dealership to see if they would be able to tell me with the VIN number. Not like it really matters will be putting a set of GTI alloys on it anyway so i would need to tell the insurance about them. Wonder how much that will add
Posted: Sun Nov 30, 2014 1:43 am |
Service Box is normally taken down on certain weekends when Peugeot are updating the service.
It will be back up Monday morning at the latest.
