Latest: williamekstrom
Overall: 17124
Online Now [87]:
Visitors: 86
Today: 10685
Total: 99342714
Forums › The Car › 206 Problems › poorly gti 180
poorly gti 180
Go to page Previous  1, 2
gaznandrea
PostPosted: Fri Dec 05, 2014 3:41 pm Up
Could it be coolant sensor because i only have to drive for short distance say 100metres and temp gauge reads 70 degrees
black peugeot 206 gti 180 lowered all round morrette headlights smoked tail lights full cobra exhaust
Carlos_WR1
PostPosted: Sat Dec 06, 2014 7:04 am Up
I wouldnt have thought the coolant sensor would cause a missfire though, when the engine is warm, if you turn the engine off and then try to restart it, does it struggle to start from warm?
gaznandrea
PostPosted: Sat Dec 06, 2014 7:08 am Up
Not if you start it straight away if you leave it ten minutes yes it does struggle to start
Carlos_WR1
PostPosted: Sat Dec 06, 2014 7:14 am Up
Could have a coolant sensor issue.
Have you had the fault codes read?
What fault codes displayed?
gaznandrea
PostPosted: Sat Dec 06, 2014 7:31 am Up
Just changed coolant sensor this morning along with oil plus filters
PostPosted: Mon Dec 08, 2014 1:32 pm Up
so any progress after changing the coolant temp.?
gaznandrea
PostPosted: Mon Dec 08, 2014 5:12 pm Up
It seems to start a bit better
Page 2 of 2
