Posted: Fri Dec 05, 2014 3:41 pm |
Could it be coolant sensor because i only have to drive for short distance say 100metres and temp gauge reads 70 degrees
| black peugeot 206 gti 180 lowered all round morrette headlights smoked tail lights full cobra exhaust | |
Posted: Sat Dec 06, 2014 7:04 am |
I wouldnt have thought the coolant sensor would cause a missfire though, when the engine is warm, if you turn the engine off and then try to restart it, does it struggle to start from warm?
Posted: Sat Dec 06, 2014 7:08 am |
Not if you start it straight away if you leave it ten minutes yes it does struggle to start
Posted: Sat Dec 06, 2014 7:14 am |
Could have a coolant sensor issue.
Have you had the fault codes read?
What fault codes displayed?
Posted: Sat Dec 06, 2014 7:31 am |
Just changed coolant sensor this morning along with oil plus filters
Posted: Mon Dec 08, 2014 1:32 pm |
so any progress after changing the coolant temp.?
Posted: Mon Dec 08, 2014 5:12 pm |
It seems to start a bit better
