Online Now [1137]:
Visitors: 1136
Today: 446493
Total: 153841504
Forums › The Car › Request a how-to › replace central brake lamp
winged_hippo
PostPosted: Sat Dec 06, 2014 12:01 pm Reply with quote Up
Hi,
I've faced the above captioned problem. Need to replace lamp but have no clue how to disassemble the cover.
I am looking forward or even forwarder to your tip as soon as possible, but possibly sooner, if possible of course.
ukskater01
PostPosted: Sat Dec 06, 2014 12:22 pm Reply with quote Up
If I remember correctly open the boot and there is two 10mm nuts to remove and it just pushes out after you unplug it
mtempsch
PostPosted: Sat Dec 06, 2014 1:38 pm Reply with quote Up
Yep, undo nuts, push out, then you get access to the wiring and the washer pipe as the light is pulled out
The rubber gasket between the light and the metal has a tendency to take a good grip, so some persuasion might be necessary to apply to the bolts in order for it to release...
At the rear of the unit there's clipped on bulb holder, the electric connector attaches to the back of the bulb holder. The washer hose attaches to a nozzle in the housing.
Press the two clips on the bulb holder towards the center of the light and separate the holder and housing. 5x T10/W5W wedge bulbs in the holder.
Silvermetallic 2004 206 RC
  Quick Reply
Username:
Message:
Quote the last message
