Online Now [294]:
Visitors: 293
Today: 38022
Total: 157344100
Forums › The Car › 206 Problems › Locking problems
Locking problems
206dr1ver
PostPosted: Sat Dec 06, 2014 6:52 pm Up
Hello all, I hope someone can help me with this.
I bought a 206, 2005, 1.4. Cars running great, with one problem which is beginning to annoy me. When I bought the car I knew the key fob wouldn't open/lock the doors. I was hoping it'd be just a new battery, however not the case.
I can lock the car from the passenger side, however from the drivers side, the key will go into the lock, but it doesn't turn at all.
Anyone know what's wrong, what I need to do to repair, or if I should go to a mechanic how much it'd cost?
Many thanks.
gazza82
PostPosted: Sun Dec 07, 2014 7:07 am Up
Could be someone has fitted a different lock or the lock is damaged?
You probably need to get the keys re-programmed to your car using PP2000 ... if they can be ...
206dr1ver
PostPosted: Sun Dec 07, 2014 2:38 pm Up
What's PP2000?
PostPosted: Sun Dec 07, 2014 5:16 pm Up
206dr1ver wrote:
What's PP2000?
Peugeot diagnostic software that the main dealer's used to use.
206dr1ver
PostPosted: Tue Dec 09, 2014 1:15 pm Up
So I need to go to a Peugeot dealer?
mtempsch
PostPosted: Tue Dec 09, 2014 1:59 pm Up
That, or see if you're close to someone on the PP2000 map (list of members here that have the gear and software)
Silvermetallic 2004 206 RC
