Latest: williamekstrom
Overall: 17124
Online Now [102]:
Visitors: 101
Today: 12810
Total: 99344824
Forums › The Car › 206 Problems › 206 headlights wont turn off not auto headlight setting
jjp0121
PostPosted: Sat Dec 06, 2014 8:54 pm Up
Hi all my 206 is a 2002 1.4lx automatic.. the headlights won't turn off at all. I locked the car and waited half hour but the lights still didn't go off, I went for a 10 minute drive to my mates and still when I turned off the car and locked it up they where on. My pals dad had a look and disconnected the battery (only removed positive terminal) and attached it again and the lights came straight on.. I've turned the light stalk on off side lights and full beam but nothing turns them off.. full beam and indicators work fine also the rear lights turn off but still the headlights remain on.. I tried the automatic lights by holding the button on the light stalk and I didn't get a beep or anything on the display so it doesn't have that function.. key was turned btw I'm going to get a free fault diagnostic done but any help is needed really because I've had to disconnect battery for the night thanks all
PostPosted: Sun Dec 07, 2014 3:30 am Up
Could be either the light stalk or switch are u/s.
PostPosted: Sun Dec 07, 2014 4:30 am Up
What if you Turn to sidelights?
jjp0121
PostPosted: Sun Dec 07, 2014 7:37 am Up
Switch are u/s ?? What's that mean pal and the sidelights come on and off but headlights stay on the whole time mate cheers
gazza82
PostPosted: Sun Dec 07, 2014 8:01 am Up
It means the switch unit is broken .. U/S - useless.
The headlight circuit is on all the time ..
Being a 2002 model that is going to require a complete Comm2000 unit as the column stalks are not separate.
PostPosted: Sun Dec 07, 2014 8:36 am Up
Could also be headlight relay.
jjp0121
PostPosted: Sun Dec 07, 2014 9:36 am Up
Yeah mate constantly on, the sidelights turn on and off perfect as does the indicators and main beam so is it likely not to be the stalk as every other function works..
PostPosted: Sun Dec 07, 2014 3:22 pm Up
I'm not sure wher the relay is, but I'd try that.
PostPosted: Sun Dec 07, 2014 4:29 pm Up
Always disconnect the negative first and connect it last, and follow the correct procedure.
Not sure if the 2002 BSI had the 'follow me home' function and that's malfunctioned.
It is possible that because it is the early software it has never had it's update and now the bug is showing.
PostPosted: Sun Dec 07, 2014 6:15 pm Up
Could be something as simple as a missing CAN node.
Planet / Diagbox time.
jjp0121
PostPosted: Mon Dec 08, 2014 9:28 am Up
After a bit more messing flicking from full beam to sidelights and turning the switch off made the lights shut off so it confirms that it's the comms unit thanks for the help guys I'm getting a second hand one fitted tomorrow for £60 including the part
stevekyd
PostPosted: Mon Dec 08, 2014 10:18 am Up
Try a liberal does of spray polish containing silicon (best) or wd40 (more messy) around the light stalk at the bottom where it goes into the dip/main beam control block. Then operate the light stalk rapidly half a dozen times or so. The mechanism gums up and wont allow the internal switch to return to the off position. This has worked a number of times for me on more than one 206. Cheaper than buying even a second hand replacement unit if it works, so got to be worth a try.
PostPosted: Mon Dec 08, 2014 1:26 pm Up
WD40 and electrics don't mix very well. It likes to set on fire near a spark.
It is oil based so gets the dust sticking to it, which basically becomes an abrasive and causes premature wear.
This is also the reason you don't use it in door locks/petrol caps etc.
Better off buying a proper electrical contact cleaner or one of the new WD40 specialist range that contains PTFE rather than oil.
