Online Now [930]:
Visitors: 929
Today: 195705
Total: 150030949
Forums › The Car › 206 Problems › H7 into H4 wiring diagram
heyziq
PostPosted: Sun Dec 07, 2014 11:23 am Up
i just bought some morrete.. how could i convert from stock H7 crytal back into H4? will i need relay
saw about into H7 but , but cant find H7 into H4,
tq in advance
heyziq.com
mtempsch
PostPosted: Sun Dec 07, 2014 2:10 pm Up
tq in advance
Don't hink I've seen one on here, but the thing you need to do is to interrupt the power to the dipped beam as the main beam comes on.
Quick sketch in paint - this should do it...
I.e., tap into the main beam line to power the relay, cut the dipped beam line and put the ends on the normally closed terminals of the relay's switch. (Or work with extensions from the original plug outwards, rather than cutting the original stuff, to minimize hassle if you want to go back.)
Silvermetallic 2004 206 RC
