Online Now [647]:
Visitors: 646
Today: 130395
Total: 155085706
Forums › Tuning, Modification & Legal › Project Cars › Project run about
Project run about
Go to page Previous  1, 2
PostPosted: Sun Nov 02, 2014 3:46 pm Up
12mm multi hex if i remember right, most are 14mm multi hex (or convetional 6 point hex)
PostPosted: Mon Dec 08, 2014 3:24 pm Up
Quick update:
Well Diagbox found the running fault, P1153 - motorised throttle body.
Picked up a good 2nd hand unit cheap to fit at weekend.
Apparently its a common problem & software update also needed.
Another job for the list.
PostPosted: Mon Dec 08, 2014 4:19 pm Up
Throttle bodies are common to fail, don't forget to learn the throttle and perform resetting of the auto adaptives.
Also did you ever update your ecu software? As ive had random fault codes when they are out of date! Or the software is playing up
PostPosted: Mon Dec 08, 2014 4:29 pm Up
Not had software update yet, its on the list
I reset auto adaptive yesterday & low speed response is better.
PostPosted: Sun Jul 12, 2015 12:57 pm Up
A little update as the project draws near to the end.
Software update the other week & the car runs & drives a lot better Cool
1 question: Anyone know where to find the auto / motion locking setting in the BSI configuration with Planet?
Also fitted heated seat kit to the leather interior I picked up the other month Cool
Thanks to the way the £ is doing against the € its far cheaper to get the kit delivered form Germany then it is to buy it in the UK Laughing
Going to do a full round up post in a few weeks when its finally finished.
Last job on the list is to clean it inside & out Wink
Sim
PostPosted: Tue Jul 21, 2015 3:53 pm Up
Lol good point, need to rummage German sale websites :))
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
PostPosted: Thu Jul 23, 2015 1:45 pm Up
A very long time since I've used PP, but I'm sure there was a Locking or something similar when you went into the BSI. Majority of the time I could only ever find the auto re-lock setting to switch on in most 206s, which was odd as I'm sure that option was only available in the SW!
That brings back memories, fitting them in the car!
PostPosted: Thu Jul 23, 2015 1:52 pm Up
Hi Lee
I've seen the auto relocking setting in the BSI.
Im going to have a look on my GLX as you activated the auto / motion locking on that one & see if I can find the settings.
Both cars have the exact same equipment for door locking / security, only the BSI unit part numbers & the software versions are different.
VorTechS
PostPosted: Mon Jul 23, 2018 10:58 am Up
Staff - Vortechs
Just came by here looking for instructions on Resetting Auto Adaptives, and discovered this line. What does a 'software update' refer to in this context please? Very Happy
(For clarity, I removed the horrendous universal cone filter previous owner added to my GTi and put a standard airbox back on... and want to do a reset to get the idle a bit smoother. Hoping that an adaptive reset will help.)
PostPosted: Mon Jul 23, 2018 11:14 am Up
The engine ecu software was updated by a Peugeot main dealer along with BSI software.
VorTechS
PostPosted: Mon Jul 23, 2018 11:17 am Up
Staff - Vortechs
Thanks. I thought that might be the case. Mind if I ask how much that set you back?
PostPosted: Mon Jul 23, 2018 11:48 am Up
£42 but was a small friendly Peugeot dealer & a Saturday morning job.
gazza82
PostPosted: Mon Jul 23, 2018 3:21 pm Up
And three years ago! Smile
VorTechS
PostPosted: Tue Jul 24, 2018 8:58 am Up
Staff - Vortechs
Haha yes. Well I can *try* my local dealer, as I've got to book the 308 GTi for its service. Is there a way I can tell if it needs an update?
Page 2 of 2
