Forums › The Car › 206 Talk › Engine block comparison: Peugeot 206 1.6XS vs Citroen C2 VTS |
Posted: Thu Dec 25, 2014 3:23 pm |
Hello friends,
I'm a proud owner of Peugeot 206 1.6 XS (Engine:TU5 JP4, 109 BHP) and recently I was offered a Citroen C2 VTS Engine (Engine: TU5 JP4S, 1.6 125 BHP).
As far as I understand these engines are almost the same except for the Head, Intake Manifold and ECU.
My question is if the blocks of these engines are the same?
Since my plan was to take the Engine Head + Intake Manifold + ECU from the Citroen and mount it onto my existing block.
Also I'm curious regarding the ECU and all sensors wiring, do I have to do any changes or it should be plug and play?
Thanks in advance for your feedback.
Regards
Posted: Fri Dec 26, 2014 3:30 am |
Why dismantle the engine when you can fit the whole thing? Pistons will be different and compression ratio will differ too.
