Posted: Fri Dec 26, 2014 4:33 pm |
The previous owner of the car must have smoked alot as the car is stinking of cigarettes a good air freshener got rid of most of the smells but when i turn the heater on it comes through the vents and it's starting to get worse. My plan is to spary some deodorizer down by the vents it takes the air from in the recalculation setting but i can't find them for the life of me and google didn't help much
Posted: Fri Dec 26, 2014 4:57 pm |
The air freshener will only mask the smell short term. Get some charcoal in a bowl and leave it in the car for a few days, should help a lot more then an air freshener.
May be worth checking the condition on the pollen filter to.
Posted: Fri Dec 26, 2014 8:47 pm |
Drivers side. Look under dash by pedals and move the slider for recirculation and you'll see the flap moving. You need to look up the dash as its right near the top towards the windscreen but you can see it.
Posted: Sun Dec 28, 2014 5:39 am |
Thanks everyone, Does the charcoal really work though?
Posted: Sun Dec 28, 2014 11:18 am |
Imelliot wrote: |
Thanks everyone, Does the charcoal really work though? |
It does yes, baking soda also works but can be a little messy to clear up in a car, just google either and your see plenty of people vouch for the method.
Posted: Sun Dec 28, 2014 12:52 pm |
Squirt anti bac in the air intake under the bonnet drivers side ( 2 vents on the bonnet) goes through the air vents in the car .
Should be fine . I would ( does not mean its ok )
Fresh filters ! Detol do some nice stinky stuff .
I would clean the seats aswell .
| If it aint broke dont fix it ! | |
Posted: Sun Dec 28, 2014 12:56 pm |
Imelliot wrote: |
waste of time .. unless you pulling or pushing the air throu the charcoal .
( so its filtered otherwise wont remove the smell )
yes charcoal does work when used correctly .
Posted: Sun Dec 28, 2014 1:40 pm |
Project2062014 wrote: |
Imelliot wrote: |
yes charcoal does work when used correctly . |
Not true, natural ventilation is enough to remove the bad smell from any car, or buoyancy-driven ventilation if you want to get technical about it. Now unless you would like a lesson in science stick to spraying your pollen filter with febreze
Posted: Sun Dec 28, 2014 7:45 pm |
Vexs wrote: |
Imelliot wrote: |
Not true, natural ventilation is enough to remove the bad smell from any car, or buoyancy-driven ventilation if you want to get technical about it. Now unless you would like a lesson in science stick to spraying your pollen filter with febreze |
Im ready for my science lesson !
Posted: Sun Dec 28, 2014 7:53 pm |
Where are the buy now charcoal car air filters ?
( Removes bad smells just leave it the natural ventilation zone .)
so ive read . Bag of coal in the boot at all times !!
No coals is removing a bad smell from a seat or car .
It only purifies the air + smell by neutralizing - &+ irons in the air ..
its not rocket science !
Posted: Sun Dec 28, 2014 7:59 pm |
Sorry i forgot to say dont forget to activate your bag of coal !
Posted: Mon Dec 29, 2014 1:23 am |
Not sure if you're genuinely a f*****g retard or just trying to humour me.
Posted: Mon Dec 29, 2014 6:03 am |
Check out his other posts and you will see lol
Posted: Mon Dec 29, 2014 12:10 pm |
mattymj wrote: |
Check out his other posts and you will see lol |
you got a brain? Think for yourself ?
Posted: Mon Dec 29, 2014 12:58 pm |
mattymj wrote: |
you got a brain? Think for yourself ? |
This comes from someone who struggled to change a fuse to get dash lights working haha
