Forums › Tuning, Modification & Legal › Project Cars › Le Bebé GTI180/RC |
Posted: Mon Jan 05, 2015 9:47 am |
I wouldn't block any passages in the head as they could interfere with any contraction or expansion of the head as it cools and heats up.
Posted: Wed Jan 07, 2015 4:23 am |
Edward wrote: |
I wouldn't block any passages in the head as they could interfere with any contraction or expansion of the head as it cools and heats up. |
Good point...
Posted: Thu Jul 23, 2015 7:04 pm |
| GTI UN JOUR.. GTI TOUJOURS. | |
Posted: Sat Jul 25, 2015 4:20 am |
That some car pron mate! Those calipers...
How big are the disks? Heard from pro_steve one can fit 307's 302mm disks and calipers just under 16in wheels (skin of teeth of space left really, but fits!)
Here's a photo
But these look not as big however 4 piston must grip like hell!
Pity we didn't catch up during pugfest, where in the world are you based?
Posted: Sat Jul 25, 2015 5:13 pm |
The disks are 288mm if I remember correctly.
Actually the piston surface of the 4-piston callipers is a lot bigger than the stock 2-piston callipers. Add the ATE disks and pads, the stainless steel braided brake lines and the Motul brake fluid and you will notice a significantly better brake performance compared to the stock brakes.
They squeak a lot though.
When I approach a bus stop and apply even the slightest pressure on the brake pedal it's like a train stopping. Most people on the bus stop get frustrated or scared.
I live in Sofia, Bulgaria.
Btw, I made a small mistake in my previous post - the spacers are 15mm. The 13mm ones didn't clear the stock wheels.
Posted: Sat Jul 25, 2015 7:06 pm |
Fair play mate Interesting to know hmm maybe they'll bed in a bit and squeak less? Awesome macro picture of more car pron from your first post!
Sofia, BG, so it says your location, for whatever weirdest reasons I thought your licence plate is French (closer look does say BG lol), your english is better than of a native speakers and pugfest was just in UK, so I got confused as to where you're from lol
Posted: Sat Aug 01, 2015 6:10 am |
Nice progress mate.
The compbrake mounts fit the Eibach just fine? They look rather thick, so I imagine they might affect the ride height?
I'm thinking about the Brembo from the V6 as well (running 15' Ultras offset 18 - the fit without spacers afaik). The 288 discs are the best option in regards to noise, 283 are worse. Do you run standard 22.2 master cylinder?
Posted: Sat Oct 24, 2015 9:08 am |
I am using the stock shocks with Eibach springs. I removed the top mounts with the KW's.
Standard master cylinder for now.
Thinking of swapping the standard GTI138 oil pan and sump for the GTI180/RC one?? Any recommendations?
