Online Now [290]:
Visitors: 289
Today: 146366
Total: 154700703
Forums › The Car › 206 Problems › 206 brakes
206 brakes
goldchain
PostPosted: Sun Jan 04, 2015 3:11 pm Up
I changed the brake light switch on my 206 and now the brakes have all locked up any ideas how to cure this
PostPosted: Sun Jan 04, 2015 4:36 pm Up
Only thing I can think off is that the link rod from the pedal to the servo is somehow being fouled from when the switch was changed, causing the brakes to lock in the applied position.
Is it all 4 wheels locked on, or just one? Might have to jack each corner up to find out. Possibly a piston has failed to return when you were checking the switch was working.
PostPosted: Mon Jan 05, 2015 1:34 pm Up
maybe it needs adjusting,i mean the pedal switch,is your car have automatic trans.?
goldchain
PostPosted: Tue Jan 06, 2015 2:55 pm Up
Many thanks all sorted the New brake switch was pushed in to far i just eased it back by
PostPosted: Wed Jan 07, 2015 2:59 am Up
good to know,I knew it needs adjusting Wink
