Online Now [422]:
Visitors: 421
Today: 138914
Total: 157160442
Forums › The Car › 206 Problems › Bouncy Idle
Bouncy Idle
206HdiGti
PostPosted: Tue Jan 06, 2015 9:57 am Up
Hello,
Recently I've noticed my idle dipping from 900rpm to 700rpm - only when cold it happens.
Is this an EGR issue?
Cheers
pro_steve
PostPosted: Tue Jan 06, 2015 10:25 am Up
Is this when stationary or when moving?
If it does it whilst coasting then it's the clutch switch.
If it does it when not moving I would get some diagnostics on there to see what is going on as it really could be anything.
www.hdi-tuning.co.uk
206HdiGti
PostPosted: Wed Jan 07, 2015 4:24 am Up
stationary.
Not EGR then?
pro_steve
PostPosted: Wed Jan 07, 2015 7:16 am Up
You could try unplugging the Egr down the back of the engine to see what happens but you WILL get lots of fault codes so you will need Peugeot Planet to clear them all.
If you bring it to me I could probably figure it out.
206HdiGti
PostPosted: Wed Jan 07, 2015 9:21 am Up
It's not causing me any issues, as it's not stalling or anything.
Bit far to drive if i'm honest mate.
Cheers for the offer anyway.
