Online Now [1042]:
Visitors: 1041
Today: 205706
Total: 151332627
Forums › The Car › 206 Problems › my gt has big handling issues
cat41
PostPosted: Thu Jan 01, 2015 12:35 pm Up
Hi.
My gt is really odd, on big rolling bumpy roads its ok but as soon as it starts hitting small rattly type bumps it becomes unstable, the streering will dance about left to right, if braking on the same types of bumps it will try and turn left suddenly or right depending on which sides the bumps are, i can feel the left trying to pull left but the right is ok or other way round. Its a odd movement.
On roads that are worn under weight it will try and follow these worn roads.
In wind its really odd, it feels if its streering from the rear, it will sway side to side in a s shape without me doing a thing with the streering, to compensate for this i,m streering right ir left on a straight road. Its a dam nightmare in wind, will only do 65 safely just.
Monday i,m having new front shocks and strut mounts.
The track rod ends are ok. The bushes are also fine.
The rear left wheel is starting to lob over, its about a pen size gap between tyer iner wheel arch, could this be making the car rear stree.
If i need a new rear axle wheres a good place to buy a referb from?
Kate
lip_88
PostPosted: Thu Jan 01, 2015 1:31 pm Up
Sounds like the rear axles had it to me I've used IMAXLES in the past and been very happy with the service and parts think it's around 220 quid from them now
sean.r.steward
PostPosted: Sat Jan 03, 2015 8:40 pm Up
lower control arms bushes ball joints or inner or outer tie rod ends. orr rack play a little is common tho muffin to worry about
axle would knock if naff
all these are common as much on Peugeot 206
cat41
PostPosted: Sat Jan 03, 2015 8:47 pm Up
Its in monday, just looked at the last mot advice from last owner, anitrol pins on bars are slightly warn and it wasn't done, really oddd is in the dry the right fron tyer stinks of burning rubber yet the other tyers don,t,
cat41
Front i mean.
PostPosted: Mon Jan 05, 2015 12:12 pm Up
Possibly worth an alignment check. Hit any big holes or kerbs hardc recently?
cat41
PostPosted: Tue Jan 06, 2015 3:24 pm Up
Ohh dear the car in the last few days has taken a turn for the worse, i,m so pleased its going in tomorrow, under power it wants to go right then braking it wants to go left, over small bumps the streering is nuts its shakes all over, at very low speeds the streering slowly goes side to side about half an inch.
If i increase the speed slightly the streering then starts shaking,
I live on a farm so have to drive half a mile on a bumpy track its not that bad to be honest just left a stone track, its fast becoming too much, the weaving is the rear axle but the shaking so on is from front end, i,m bothered if the problem isn't found it will have to come off the road.
The wheels are the nimrods which came with it when new, i wonder if there's a fault in them, i,ve change the front right to the spair but its the same.
I,m limited to 65 mph at moment, go over that and its a full workout. I can feel at 60 a thumping feeling through the streering as well as shaking.
its had new lower bottom arms. Its getting new shocks and struts, the right shock is leaking so its not performing as it should.
Help i have a sick GT.
Vexs
PostPosted: Tue Jan 06, 2015 4:14 pm Up
I get a sneaky suspicion that this will put a sizeable dent in your back pocket unfortunately.
My GTI 180
My Old 1.4 8v
cat41
PostPosted: Tue Jan 06, 2015 4:25 pm Up
Thanks and don't i know it, my dam debt card can't take no more lol,
As i know it, you got antiroll bushes and they are ok. The mot from last owner stated antiroll bush pins have play and wasn't sorted.
the shocks and strut mounts are old and has done 100000 miles, right shock is weak due to leak, i,m having sachs shocks tomorrow fitted to front, with new struts.
