Online Now [395]:
Visitors: 394
Today: 105837
Total: 156212560
Forums › The Car › 206 Problems › engine timing
engine timing
gaznandrea
PostPosted: Wed Jan 07, 2015 11:44 am Up
When timinng a gti 180 were should pistons be when crank pin located
black peugeot 206 gti 180 lowered all round morrette headlights smoked tail lights full cobra exhaust
gazza82
PostPosted: Wed Jan 07, 2015 11:59 am Up
It should mean pistons 1 and 4 are at TDC ... you should only be able to pin the crank in one place ...
(That's based on our 138 though)
PostPosted: Wed Jan 07, 2015 12:43 pm Up
The 180 pin is on the flywheel at the back at the engine, requires a special tool
gaznandrea
PostPosted: Wed Jan 07, 2015 12:51 pm Up
Are the pistons still tdc on 180
PostPosted: Wed Jan 07, 2015 3:21 pm Up
Using the special timing tools to lock the crank & cams you can't really get it wrong.
Don't attempt to fit the timing belt without the special locking tools.
gaznandrea
PostPosted: Wed Jan 07, 2015 3:37 pm Up
Were is timing hole location on 180 as when piston 1 is tdc exhaust valves are open
PostPosted: Thu Jan 08, 2015 12:00 pm Up
I dont know, just time it correctly. The bottom pulley is floating so either do it correctly or run a risk
PostPosted: Thu Jan 08, 2015 12:07 pm Up
PostPosted: Thu Jan 08, 2015 12:54 pm Up
Im so confused......
