Online Now [343]:
Visitors: 342
Today: 157467
Total: 155248888
Forums › Tuning, Modification & Legal › Project Cars › My sw v6 project
My sw v6 project
pugsyhdi
PostPosted: Sun Jan 11, 2015 10:41 pm Up
Edward wrote:
And is it a 5 speed box on the V6?
Yes it is the standard V6 one
It would be like trying to put a 1.6 shaft in to a 2.0 box they don't fit
PostPosted: Mon Jan 12, 2015 2:41 am Up
The 1.6 shafts and hubs aren't as big as GTI/diesel parts. Any shaft from a Be4 gearbox would have been a better start.
yeti86
PostPosted: Mon Jan 12, 2015 3:29 am Up
1.6 16V has the same hubs as gti
pugsyhdi
PostPosted: Mon Jan 12, 2015 4:39 am Up
Some 1.6 would have same ends on it as a 2 litre but I would imagine the back mount in different position so would not fit as long one goes throw it
No BE shaft will fit as I say the diff/box ends are different also the distance from box to the back mount is different
I might managed to make one without welding but I though if I was welding one might as well do both as 3.0 shafts better
pugsyhdi
PostPosted: Mon Jan 12, 2015 9:04 am Up
one with more splines is v6 one totally different
bottom one v6
3 different inputs to 3 different boxes
PostPosted: Mon Jan 12, 2015 9:11 am Up
Would a Be4 box fit the V6 ?
pugsyhdi
PostPosted: Mon Jan 12, 2015 9:18 am Up
No totally different and probably would not be as strong
PostPosted: Mon Jan 12, 2015 9:40 am Up
You only running 200, shaft strength is a concern. I would personally be fitting the be/206 shaft ends to the 406 shafts/inputs
pugsyhdi
PostPosted: Mon Jan 12, 2015 10:52 am Up
As I say tried that still need cut so best to use strongest shaft also way I welded them I have no worry
omega
PostPosted: Mon Jan 12, 2015 3:32 pm Up
that drive shaft looks scarey to me
looks a nighitmare to wire up
good luck
1245678
PostPosted: Mon Jan 12, 2015 5:10 pm Up
I ment to say NOT a concern, but still that welded shaft looks dodgy as!
Best of luck anyways though
DeadEyePaul
PostPosted: Tue Jan 13, 2015 3:49 am Up
Davemac might be able to fabricate you one? My driveshaft broke on my v6 and i sent them my old one. I got the d9 in mine
www.gripperlsd.com/
pugsyhdi
PostPosted: Tue Jan 13, 2015 4:35 am Up
I'm not worried about it just looks bad in pic plus its nice and rusty. yes wiring is great fun need to run 2 ecus trying to get all under bonnet is to fun
pugsyhdi
PostPosted: Tue Jan 13, 2015 4:38 am Up
www.gripperlsd.com/
If I find I do have a problem what ruff price I'm I looking at thanks
DeadEyePaul
PostPosted: Tue Jan 13, 2015 4:45 am Up
Irc £300
Page 2 of 3
