Posted: Sun Jan 11, 2015 10:41 pm |
| Edward wrote: |
| And is it a 5 speed box on the V6? |
Yes it is the standard V6 one
It would be like trying to put a 1.6 shaft in to a 2.0 box they don't fit
Posted: Mon Jan 12, 2015 2:41 am |
The 1.6 shafts and hubs aren't as big as GTI/diesel parts. Any shaft from a Be4 gearbox would have been a better start.
Posted: Mon Jan 12, 2015 3:29 am |
1.6 16V has the same hubs as gti
Posted: Mon Jan 12, 2015 4:39 am |
Some 1.6 would have same ends on it as a 2 litre but I would imagine the back mount in different position so would not fit as long one goes throw it
No BE shaft will fit as I say the diff/box ends are different also the distance from box to the back mount is different
I might managed to make one without welding but I though if I was welding one might as well do both as 3.0 shafts better
Posted: Mon Jan 12, 2015 9:04 am |
one with more splines is v6 one totally different
bottom one v6
3 different inputs to 3 different boxes
Posted: Mon Jan 12, 2015 9:11 am |
Would a Be4 box fit the V6 ?
Posted: Mon Jan 12, 2015 9:18 am |
No totally different and probably would not be as strong
Posted: Mon Jan 12, 2015 9:40 am |
You only running 200, shaft strength is a concern. I would personally be fitting the be/206 shaft ends to the 406 shafts/inputs
| Team Impossible Possible
Posted: Mon Jan 12, 2015 10:52 am |
As I say tried that still need cut so best to use strongest shaft also way I welded them I have no worry
Posted: Mon Jan 12, 2015 3:32 pm |
that drive shaft looks scarey to me
looks a nighitmare to wire up
good luck
Posted: Mon Jan 12, 2015 5:10 pm |
I ment to say NOT a concern, but still that welded shaft looks dodgy as!
Best of luck anyways though
Posted: Tue Jan 13, 2015 3:49 am |
Davemac might be able to fabricate you one? My driveshaft broke on my v6 and i sent them my old one. I got the d9 in mine
www.gripperlsd.com/
Posted: Tue Jan 13, 2015 4:35 am |
I'm not worried about it just looks bad in pic plus its nice and rusty. yes wiring is great fun need to run 2 ecus trying to get all under bonnet is to fun
Posted: Tue Jan 13, 2015 4:38 am |
| DeadEyePaul wrote: |
www.gripperlsd.com/ |
If I find I do have a problem what ruff price I'm I looking at thanks
Posted: Tue Jan 13, 2015 4:45 am |
Irc £300
