Online Now [58]:
Visitors: 57
Today: 47285
Total: 117297189
Forums › The Car › 206 Talk › Axle and Rear Exhaust
Spotfist
PostPosted: Mon Jan 12, 2015 7:54 am Up
Hi all, was wondering if anyone could help with costing up the job below
I am having my rear axle replaced and the garage I took it too suggested I get the exhaust replaced at the same time as whoever owned the car before has put the exhaust on wrong so it's rattling about. The exhaust will only be replaced from the cat back excluding the cat.
The garage has said that the job will cost £385 excluding VAT,
200 for the axle
80 for the exhaust
and then 3 hours labour at £105,
Does this seem like a reasonable price? I know the axle is 200 and assumed 100 to fit so the price looks good to me with the exhaust fitted at the same time pretty much free?
Cheers
PostPosted: Mon Jan 12, 2015 8:49 am Up
Where are they sourcing the axle from? Re-conditioned? Or Second hand?
MrWhite
PostPosted: Mon Jan 12, 2015 9:00 am Up
sounds ok to me as the place I source axles from and recommend, supply and fit for around 300 so If its reconditioned then yes
if second hand no
My 206 Project Thread
Spotfist
PostPosted: Mon Jan 12, 2015 9:04 am Up
I am getting the Axle myself from Axles Direct so it's re-conditioned. The garage suggested I did it that way as it avoids them having to put tax on it.
DREWDEN
PostPosted: Mon Jan 12, 2015 11:22 am Up
£105 quid is a cracking price to take off and fit a exhaust and rear axle at a garage.
My friend took off and replaced my axle for £100 and that was cheap.
206 2ltr Hdi glx 53 plate
Spotfist
PostPosted: Mon Jan 12, 2015 12:16 pm Up
Cheers for that, I found a place that specialises in them and they fit them for 300 all in but is a trek to get there. I then went to this garage and they said they would fit it pretty much for the same price. I also said there would be work coming there way in the future as it needs more doing for the mot.
Although they will probably hike the price up and say the wheel fell off etc.
MrWhite
PostPosted: Mon Jan 12, 2015 1:16 pm Up
Thats the company I recommend I got mine done there they are the Dogs Danglers bud.
Spotfist
PostPosted: Mon Jan 12, 2015 1:28 pm Up
Cheers for the info man! Can't wait to get the car sorted, no more banging, knocking and p**sing myself on every corner for fear of the wheel coming off!
DREWDEN
PostPosted: Mon Jan 12, 2015 2:53 pm Up
My rear axle bearings were in good nic, it was the front rubber mounts that had worn and a bit of play in them, so i bought a decent second hand axle from the scrappies £100 with low mileage, and cleaned it up and repainted, then swapped over.
My project when the warmer weather comes is to refurbish the old axle, new bearings and rubber mountings and keep as spare or sell on.
Spotfist
PostPosted: Mon Jan 12, 2015 4:22 pm Up
Ye I think mine is foowked! The wheel was dented so had to get the alloy fixed, tyre was egg shaped so had to get a new one. One of the previous owners ripped the plastic trying to wire up the stereo instead of checking how to get the crews out?!?!?
The arm that pivots on the rear, doesn't pivot and instead the whole joint moves up and down and a bolt is half hanging out but is seized. Must have been some pothole!
Spotfist
PostPosted: Thu Jan 22, 2015 9:58 am Up
Just an update on this,
Cost a bit more in the end (Surprise, Surprise) I know it would though.
Exhaust was 80 as stated.
Labour required an extra hour so 140 no 105
The big extra cost has come from the replacement of the ABS sensors, the axle was corroded to hell and gone, never been replaced so looked like the original from 1999, everything was pretty welded in place including the sensors so that added an extra 65 to the bill.
So that brings the total to 485 with the axle at 200 pounds. 100 over the original estimate, the drive home was bliss though, no banging, squeaking, clunking! I was in GTI heaven lol Wink
MrWhite
PostPosted: Thu Jan 22, 2015 1:28 pm Up
peace of mind bud its well worth it. Happy driving ^_^
Spotfist
PostPosted: Thu Jan 22, 2015 2:08 pm Up
Too bloody right! My hands hurt from clutching the steering wheel so hard over every bump! Can't wait to drive it again now lol
