Posted: Tue Jan 13, 2015 6:34 pm |
Are they larger diameters? If not i wouldnt worry, i may consider a paddle clutch as you did say about future engine upgrading
| Team Impossible Possible
Posted: Tue Jan 13, 2015 6:47 pm |
Addaz wrote: |
Are they larger diameters? If not i wouldnt worry, i may consider a paddle clutch as you did say about future engine upgrading |
Not so sure about diameter, I think the 180 one is a tad lighter than the 138. I'll have to pull the one out of my scrap 138 lump and weigh them both.
Posted: Wed Jan 14, 2015 6:25 am |
Well the thrust bearing decided to well and truly s**t itself this morning, and take out the crank sensor with it. Picking up an LUK clutch this afternoon for £86.26 + VAT. Car will be back on the road by this evening.
Posted: Wed Jan 14, 2015 6:33 am |
LeeThr wrote: |
Well the thrust bearing decided to well and truly s**t itself this morning, and take out the crank sensor with it. |
No comment
Posted: Wed Jan 14, 2015 6:42 am |
MrBSI wrote: |
LeeThr wrote: |
No comment |
Serves me right for trying to be organized about it all. Could guarantee if I hadn't have given it so much as a second thought it would have lasted until next week when I was planning on getting it up on axle stands for a couple of days.
Ah well, ive got a couple of good crank sensors lying about. Few hours in the garage this afternoon and it'll be good to go again.
Posted: Wed Jan 14, 2015 10:15 am |
Had the same problem myself. The clutch was fine but the cable and thrust bearing failed. I don't reckon it's possible to get an uprated thrust bearing in general?
| Current: Albi Blue Clio 197
Previous: EZR 1.1 206 Zest 3 5dr | |
Posted: Wed Jan 14, 2015 10:21 am |
Right hand drive GTI is a hydraulic clutch so there isn't a cable to worry about - just a slave cylinder instead.
The standard thrust bearing with a decent brand of clutch kit will be fine.
Posted: Wed Jan 14, 2015 5:01 pm |
Bit of grease on the input draft for the bearing doesn't hurt either. I replaced my salve cylinder as well when I did mine. Old one had a leak in it somewhere. Had to bleed it every few months.
Posted: Thu Jan 15, 2015 4:03 am |
