Latest: tc.206
Overall: 17147
Online Now [165]:
Visitors: 164
Today: 2859
Total: 116499489
Forums › The Car › Solved 206 Problems › Attempt to reset bsi, advice?
Watkins92
PostPosted: Fri Jan 16, 2015 7:06 am Up
I am about to attempt to reset my bsi, car is 2000 plate 2.0 gti, except every instructions I've read involves lowering the drivers window. I'm attempting the reset because my windows no longer open, is it safe to do it when I can't open the window? Thanks.
PostPosted: Fri Jan 16, 2015 7:25 am Up
2000 GTI is a NON plexed electrical system, no need for a BSI reset on these.
Watkins92
PostPosted: Fri Jan 16, 2015 7:48 am Up
Oh. I was attempting to do it because my electric windows have stopped working, would it do absolutely nothing then? Back to the drawing board it is...
PostPosted: Fri Jan 16, 2015 7:51 am Up
If both windows have stopped working then check the fuse & window switch are both ok.
DREWDEN
PostPosted: Fri Jan 16, 2015 8:03 am Up
Did you disconnect the battery, when you worked on trying to fix your cigarette lighter.
I know on multiplex you should always disconnect the battery supply, as you can cause damage to the electrical system. not sure on preplex though, (i should imagine you can).
206 2ltr Hdi glx 53 plate
Watkins92
PostPosted: Fri Jan 16, 2015 8:09 am Up
MrBSI, there is no fuse correctly labelled for the windows, any ideas what number I'd need? And I'm gonna get a multimeter today and give it a check to see whether it's just the switch needs replacing.
Watkins92
PostPosted: Fri Jan 16, 2015 8:18 am Up
DREWDEN, I did not, my car is pre-plexed. Would I likely to have damaged the switch? I'll see if I can pick one up at a scrapyard/eBay and hope for the best I guess haha
Watkins92
PostPosted: Fri Jan 16, 2015 10:27 am Up
How do I delete this thread? Windows are now fixed and no need to reset bsi.
PostPosted: Fri Jan 16, 2015 11:24 am Up
Moved to Solved.
What was the solution? Might be useful to others in the future.
