Online Now [336]:
Visitors: 335
Today: 95161
Total: 155965264
Forums › The Car › 206 Talk › morettes on preplex gti
Forum Index › 206 Talk
pumba
PostPosted: Tue Jan 20, 2015 5:23 pm Up
Hi guys sorry if its been asked before, when fitting morettes to a gti do you need the relay or is the relay for h4 to h7 conversion only.also im going to fit a hid kit aswell the car is a 2000 plate gti with h7 crystals atm thanks all in advance
PUMB@206
gazza82
PostPosted: Wed Jan 21, 2015 3:46 am Up
Relays is for H4 to H7 only
Wouldn't bother with HIDs .. just annoy other drivers ...
mtempsch
PostPosted: Wed Jan 21, 2015 9:27 am Up
Aren't morettes dual bulb just like stock crystals (2xH7) but in separate housings and possibly 1xH7+1xH1?
Is the the dipped beam meant to stay on along with the main beam? If so, I'd believe the relay setup is needed.
Silvermetallic 2004 206 RC
pumba
PostPosted: Wed Jan 21, 2015 11:01 am Up
Thanks guys an yes dipped are h7 an mains got h1,but has a h4 to standard peugot plug so thought that was for h4 to use relays
PUMB@206
mtempsch
PostPosted: Wed Jan 21, 2015 11:34 am Up
In general, for a single bulb (H4) to dual bulb (crystal / morette) upgrade, to keep the dipped beam on when the main beam comes on, you need to
* either provide an alternate power source for the dipped bulb (via relay) while the main is on (and the car turns the dipped off)
* or make the car itself keep the dipped beam on by changing BSI settings to 'dual optics', IIRC. Don't know whether that's possible on a pre-plex car.
